setting tappets on 5k?????
Postby 3T-Rona » Wed Jul 27, 2005 6:51 pm
how do i reset the tappet in my 5k..... theyre starting to rattle audibly and i dnt like it :)
how do i adjust them and what should the b set to, im pretty sure it doesnt have hydraulic lifters as it has a lumpy cam (as told u cldnt hav hydraulic lifters with aftermarket cam???)
cheers al
3T-Rona
Postby 3T-Rona » Wed Jul 27, 2005 9:44 pm
anyone>?
3T-Rona
Postby samlloyd » Wed Jul 27, 2005 9:51 pm
i know i know!!!!
Buy new rocker cover gasket.
Tools: Prob a 10mm spanner,flat head screw driver, spark plug socket, feeler gauge, haynes manual or similar.
Find the tappet clearences from the manual. Do when car is cold
Find correct feller lever
Take all spark plugs out, so your not fighting compression.
Starting with Cyl 1, Rotate crank untill pison is at Top Dead Centre on the firing stroke.
Undo that top 10mm nut on top of p/rod
put the feeler gauge in between the rocker and the p.rod(i think its the p.rod its hitting?)
While the spanner is still on the nut, tighten with flat head screw driver
LEFTY LOOSEY,RIGHTY TIGHTY
Tighten untill the feeler gauge can slide in with a bit of resistance but not much.
Leave Screwdrive ontop of flathead screw your adusting on top of the p.rod, while you tighten up that 10mm bolt.
Rotate crank a bit more untill the next piston is up. You know this buy gentally poking screwdriver down the sparkplug hole. Keep a hold of it though so it doesnt scrape the cyl. Bore. Just before you feel piston going down, thats where it should be.
To turn crank, push the fan around.
Repeat on remaining cyls.
(im 16, correct me if wrong)
(my expecerience was on a datsun 1200, so hope its similar)
samlloyd
Postby Ae92typeX » Wed Jul 27, 2005 9:56 pm
I was under the impression the 5k is hydraulic
if it has tappets (I dont know the older toyo motors much), they are generally pretty easy to set. Take off the rocker cover, you will see the rockers. On one side of these will be a nut, inside the nut a shaft with a flat head screwdriver head. Basically, you get the rocker in question to the point where it has the most gap between it and the valve (i.e. when it is not open). Usually, for example, you meauser valve #1 when #8 is fully open- but this will depend on the individual engine. you then loosen the nut, and screw the head down to the correct gap measuring with a feelergauge. Tighten the nut back up, measure again and done.
Thats how to do them, but you do need the spec's. If no one has them here, just go to the library.
Ae92typeX
Postby solberg Fan » Wed Jul 27, 2005 11:10 pm
If you have a lumpy cam, ring the company up who modified it and tell them the cam specs. They may have a diffrent clearence setting compared to toyota specs.
I have no idea if it has hydralic tappets, but i wouldnt have thought so. :?
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
