Heater on 4age
Heater on 4age
Postby NA Drifter » Wed Jul 27, 2005 11:24 pm
I wondering, if there many peoples have problem with their heater not hot/warm?
Seems like no heater in my AE86,.. even after taking out the A/C condensor alloy thing inside the car.
or is that common with 4age engine? I'm running everything factory heating stuff and got thermostat too. Checked the heater linkage valve on firewall, and seem to work fine.
Keith
NA Drifter
Postby Dell'Orto » Wed Jul 27, 2005 11:43 pm
Heater core might be blocked?
You do have water right :P :lol:
Postby matt dunn » Wed Jul 27, 2005 11:49 pm
Mmm, Boost wrote:Heater core might be blocked?
Yeah, heater cores quite often get blocked.
Take the hoses off that go thru the fire wall and run a hose through them in both directions untill the water runs clear.
matt
Postby Mr Revhead » Wed Jul 27, 2005 11:53 pm
take ONE hose off, and flush it both ways, make sure the tap is to hot. if its blocked your best to flush the whole system. then fill with new coolant
Postby NA Drifter » Wed Jul 27, 2005 11:57 pm
cool, cheers! , yeh, Brad, it have got water :D
is not that fun to have long drive with no heater you know!.. desert road.... 8O .. in winter,,..
will do that and hopefully will have the heater back!
Keith
NA Drifter
Postby matt dunn » Thu Jul 28, 2005 12:06 am
Mr Revhead wrote:take ONE hose off, and flush it both ways, make sure the tap is to hot. if its blocked your best to flush the whole system. then fill with new coolant
If you take one hose off you have to use a lot of pressure to unblock it as you are pushing against the restriction in the heater and the restriction in the whole system.
That may put too much pressure on the heater if it's thats blocked and split the core.
You may have to use quite a bit of pressure. When I do thuis at work some have needed quite a bit.
Also you flush all the shit into the engine where it circulates around and back intgo the heater.
Matt
Postby 20vpsi » Thu Jul 28, 2005 12:08 am
yer im having the same issues with mine, i dont think it's the heater core i think it might be the heat adjuster it'self, i found that mine is electrical controled when you slide the temp to the heat you wont its not making correct contact so its stuck on one heat...
current ride:
Toyota carib.
Toyota levin AE86
Previous ride: Turbo 20v Toyota Trueno
20vpsi
Postby Mr Revhead » Thu Jul 28, 2005 12:09 am
if you back fluch 1st, it should dislodge it, by flushing it both ways untill it runs clear youll clear all the crap out :wink:
if its real blocked then yeah doing only the heater may be easier, but while your there ud be a fool not to do the lot, cause if there shit in the heater, therell be shit in the block
Postby method » Thu Jul 28, 2005 12:10 am
my heaters bloody hot, thing is i cant turn the $&#$% off :lol:. Have to pop the bonnet and manualy ajust the thing that sends water to the heatercore to turn it off 8)
PICS UPDATED DAILY
method
Users browsing this forum: Google [Bot] and 19 guests
