oil change
oil change
Postby mad924 » Thu Jul 28, 2005 12:39 am
Hi all,
My first post :)
I have a '93 corona 2L auto. its a hack car but I still look after it.
tomoro during my lunch break I'm taking it to a section at work that has a pit i can use, but since I'll be pressed for time and i have no manual I have some qusetions:
-i honestly havent looked to hard at my engine yet, just enough to compare my new oil filter to the old one. first time on a east-west fwd car too. where do i top up the ATF?
-where can i find the sump plug and the ATF drainage plug? Are they hidden behind stone guards/ engine shields?
Any help I get, the quicker i can do the job and be back at work!
TIA!
mad
mad924
Oil change
Postby jzz30 » Thu Jul 28, 2005 2:00 am
Top it up throught the dip stick.
jzz30
Postby mad924 » Thu Jul 28, 2005 8:24 am
i'll use a straw too...
mad924
Postby Spannergal » Thu Jul 28, 2005 10:02 am
sump plug is at the bottom of the oil sump. should be fairly easy to find - from experience I'd say you'll need a 14mm spanner or socket. I'd also check that the oil filter is the right one before draining any oil from the engine.
in terms of drainage for atf, hadn't actually thought about it - as generally on vehicles I've been near, if you're changing atf you want to flush the trans, which I don't think would be worth attempting if you have a lack of time.
Spannergal
Postby mad924 » Thu Jul 28, 2005 10:48 am
Cheers lyn_m :)
good point re: flushing trans. Will have to leave it for another day.
mad924
Postby solberg Fan » Thu Jul 28, 2005 11:20 pm
mad924 wrote:i'll use a straw too...
I dont get it :|
Use a funnel :) A lot easier
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby Bling » Fri Jul 29, 2005 1:20 am
i think they are refering to how they will get the oil out :lol:
