Curzing home from work tonight, and went to change gear as I normaly do (not racing or anything, just a normal upshift) put the clutch peddle in, and now wont come out. The only bit of luck was I was only 500m from home.
I have had a look at the master cyclinder, and the oil lines, and everything appares to be OK, the slave cyclinder is mounted as it should be, and the leaver the the slave cyclinder pushes appares to be free enough (not too sure if it is too free or not)
What else can I check? Or is it a split box/engine time?
Thanks
Neil
