Im hoping to remove, inspect and replace my head with a new gasket in one day, can it be done without having to reset the timing etc? Is there a trick to keeping tension on the cam-belt while I take off the cam pulleys and then remove the head? (I have heard there is a spring on the cam-belt tensioner that might pop out if I'm not careful and be a pain in the arse...)
Any help much appreciated
