turbo manifold
turbo manifold
Postby soopachargen » Thu Aug 04, 2005 4:39 pm
i know this sounds kinda cheap... and im aware of spending the extra money to do it properly.... but...
Could you make up a collector to go on the end of the 20v primaries to mount a turbo on?? eg have a 3inch long section off the end of the primaries that has your turbo on it?. or are the primaries too long??
Anyone wish to share some pros and cons of the idea before saying dont be a cheap arse... just go and pay 800ish for a proper tuned manifold.
When in doubt, down and out.
soopachargen
Postby Malcolm » Thu Aug 04, 2005 4:46 pm
I'm not 100% familiar with 20v's, but the usual problem with using a stock NA manifold for turbo is that it makes the turbo sit too low, which is a big problem for oil drainage (has to be higher than the oil level in the sump to allow proper drainage). If you want a cheap option, you can make a simple log manifold, which has a common pipe running across the front of the exhaust ports, with each port having a short length of pipe going into this common one. You then mount a flange onto the common pipe for your turbo. This method also gives very short runners, which is good for turbo response.
Postby Lloyd » Thu Aug 04, 2005 6:24 pm
GOnna sit pretty low. And you should be able to get a nice spaghetti manifold made up for about half that price. Could probably sell you my 20V one in a month or so if you're still looking for one
Postby soopachargen » Thu Aug 04, 2005 7:18 pm
sounds interesting... why dont you want yours anymore hrt? im just building in my head at the moment. Would be keen to see some pics dude.
soopachargen
Postby Lloyd » Thu Aug 04, 2005 10:30 pm
Motor is eventually going into my KE20 and I'll be changing to a high mount manifold. Pic below, 2 layers of heat wrap individually around each running. About $100 worth of heat wrap alone
Postby 1598cc » Thu Aug 04, 2005 11:55 pm
All_Fours wrote:I'm not 100% familiar with 20v's, but the usual problem with using a stock NA manifold for turbo is that it makes the turbo sit too low, which is a big problem for oil drainage (has to be higher than the oil level in the sump to allow proper drainage). If you want a cheap option, you can make a simple log manifold, which has a common pipe running across the front of the exhaust ports, with each port having a short length of pipe going into this common one. You then mount a flange onto the common pipe for your turbo. This method also gives very short runners, which is good for turbo response.
bang on, but log manifolds are pritty shit.
1598cc
Postby soopachargen » Fri Aug 05, 2005 10:21 am
nice manifold.... is that an evil si one or a nite parts...?? or someone else?
soopachargen
Postby Lloyd » Fri Aug 05, 2005 6:38 pm
Not entirely sure, quite possibly a Niteparts one. Bought it off Phat_GTZ as he decided not to go turbo or something
Postby strx7 » Sat Aug 06, 2005 4:08 pm
All_Fours wrote:This method also gives very short runners, which is good for turbo response.
Equal length longer pipes, preferably tuned length, IE extractors, before the turbo give SUPERIOR responce to what short runner ever will.
Find some pics of turbo'd F1 cars from the 80's.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
