Silicone brake fluid
Postby Jebus » Thu Aug 04, 2005 7:19 pm
Any one got any other info on this stuff, I understand that it doesnt damage paint, and doesnt absorb water so probaly wont need replacing. But how effective is it against standard 5.1 or the likes? Is it fine with a standard brake setup?
Jebus
Postby bad20v » Thu Aug 04, 2005 7:30 pm
Check the 'FAQ' section under brakes and stuff for your answer dude.
Thank-You.
bad20v
Postby Malcolm » Thu Aug 04, 2005 7:34 pm
in short, don't use it unless you want to replace it every few months
because it doesn't absorb water, as moisture builds up it forms in droplets in the fluid, which will boil at 100 degrees C and fade much faster than even very old mineral based fluid.
Postby Jebus » Thu Aug 04, 2005 7:37 pm
Oh I see, that answered my Q. Ill check FAQ next time.
Cheers :)
Jebus
Postby bad20v » Thu Aug 04, 2005 8:06 pm
Welcome, always happy to help another toyota fan from papakura! :D
Thank-You.
bad20v
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
