Simon85MR220v wrote:And if you have, did you also work out how much to take off for the domed pistons? I've used a TRD 0.8mm head gasket but the head already had 0.4mm off it as well so I'm wondering what the compression ratio is now. Its also an interference motor now so hopefully I don't break a cambelt
