CT20 on a 4efte
CT20 on a 4efte
Postby stevo » Fri Aug 05, 2005 7:30 pm
I was just wanting to no if a CT20 turbo off a 2L-t surf would be to big for the littel 4efte?
Im asking becouse ive been offerd one in pritty good condition and i can get a manifold made pritty cheap.
stevo
Postby dotdog » Sat Aug 06, 2005 11:00 am
Ive heard they are a real pig of a turbo, spend a lil bit more and get a t3 or simillar for it
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby loose_unit » Sat Aug 06, 2005 8:14 pm
TD04L would be a much better option, CT20's are pretty inefficient.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby Stu- » Sun Aug 07, 2005 4:05 pm
Give it a go! I've had one of those turbos (didn't use it thou) and they're not actually that bad. Probably a good combo for a 1300.
Project Thread
Stu-
Postby stevo » Sun Aug 07, 2005 5:06 pm
yeah i was thinking of putting a tdo4 how mush modifing does it take with oil lines etc
i heard a ct12 is a no better then the ct9
does any one no how much it is to get the ct9 high flowed and who does it in hams if thats a good option?
stevo
Postby Si » Sun Aug 07, 2005 5:46 pm
there are 3 ct12's, which one are you comparing to the ct9?
Current: , '96 SubaruImpreza
Si
Postby stevo » Sun Aug 07, 2005 6:00 pm
dont no much about the ct12's thats just what i got told
stevo
Postby Si » Sun Aug 07, 2005 8:35 pm
ct12 = off a 1ggte (2L twin turbo)
ct12a = off a 1jzgte (2.5L: twin turbo)
ct12b = off a 2jzgte (3L twin turbo)
Si
Postby QikStarlie » Sun Aug 07, 2005 11:07 pm
ct12 off a 2et is what he'll be taliking about as its the only one that bolts on.
witch is a step sidways from a ct9...
talk to stu- ^^^^ about a hiflow
QikStarlie
Postby loose_unit » Mon Aug 08, 2005 12:50 am
CT12 D off a Hiace Diesel also.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
