spark plug problem
spark plug problem
Postby JASON_SHEMAN » Tue Aug 09, 2005 7:30 pm
i'm using NGK-R Platinum spark plugs BKR6EP-11 for my st-182 non-turbo celica, but i found that the aceleration is slower than the cheapest ngk spark plug...y??
thx
JASON_SHEMAN
Postby TrouserFxGt » Tue Aug 09, 2005 8:25 pm
not really surprising.
the platinums last longer, the standards are more effective.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby Lloyd » Tue Aug 09, 2005 8:29 pm
You shouldn't notice a difference. They reckon the platinums give a high spark gap voltage and all that due to a small surface for it to jump from (more concentrated spark or something like that). They last longer, thats about it.
Postby Jebus » Tue Aug 09, 2005 8:37 pm
Its not all in your head?
Jebus
Postby JASON_SHEMAN » Tue Aug 09, 2005 8:42 pm
AND ONE THING I JUST FIND IN THE NGK WEBSITE IS THEY SUGGEST TO USE BKR6EP-8 INSTEAD OF BKR6EP-11 ....BUT, DOES IT MATTER?
JASON_SHEMAN
Postby Lloyd » Tue Aug 09, 2005 9:03 pm
Depends what the old plugs were gapped to
And please turn caps lock off
Postby Jebus » Tue Aug 09, 2005 9:22 pm
the -XX at the end of the number is what the plugs are pre-gapped to, find your old plugs and see if they have a -XX number after the code. Otherwise check the gap on them and see if it closer to .8mm or 1.1mm
You probaly wont notice a difference between platinums and regulars ones if theyre the same plugs. But if one set is colder or warmer then you might.
Jebus
Postby JASON_SHEMAN » Tue Aug 09, 2005 9:42 pm
Can the 1.1 one re-gap to 0.8?
and how can i know its colder or warmer?
JASON_SHEMAN
Postby Lloyd » Tue Aug 09, 2005 9:50 pm
Yep, can regap them. Get a set of feeler gauges and set it to whatever size gap you want.
As for the hotter colder thing, thats what the number refers to in the code for the plug. 6 is the next colder plug down from a 5.
