squeek when cliutch outpressed
Postby GTCRSHR » Sat Aug 13, 2005 12:04 pm
Hi guys just a weird one ... was listening to my motor last night while driving along and noticed this noise ....
it sounded to me like a belt slipping the squuek that you get when thats happening only very subtle .... i couldnt for the life of me figure out what it was untill i sat in the drive way and tried a few things
its only a very like squeek when the clutch is NOT pressed in (ie normal driving)
and when you press it down even just a tad it goes away ...
its not the pedal its in the engine bay some where
any iodeas ? pressure release bearing going ?
thanks for any help
its a ae101 corolla fxgt with 80odd thou km
Nothing to see here ...
GTCRSHR
Postby 3T-Rona » Sat Aug 13, 2005 7:28 pm
thrust bearing worn? r they cable or hydro clutch?
3T-Rona
Postby Akane » Sat Aug 13, 2005 7:57 pm
no, thrust bearing is at it's maximum stress when you push the clutch in, don't give wrong info out if you're not sure.
(That's for most types of cars as far as I know, there might be some weird pull type gearboxes)
Postby GTCRSHR » Sun Aug 14, 2005 4:11 pm
or the sound of a loose pully .... but as the clutch isnt on the pully 8O :P
GTCRSHR
Postby Ae92typeX » Sun Aug 14, 2005 7:16 pm
had an worn input bearing in a mates gts25 gearbox make sortof similar noise. When you touched the clutch pedal it went away. wouldnt call it a squeal as such, but also didnt sound like a bearing...
Ae92typeX
Postby sergei » Sun Aug 14, 2005 7:19 pm
the bearing actually can make noises while not loaded... squeak is one of them. There is a way to check it - push fork towards the clutch slave cylinder (compressing it along the way), it will move the bearing away from plate, so it will not rotate, if noise dissapears, you will know what is wrong.
Postby Akane » Sun Aug 14, 2005 8:59 pm
Yes, my apologies, I'll take what I said back.
The bearing can make noise in such a way that it only makes noise when there's no load to it.
Postby GTCRSHR » Fri Aug 19, 2005 11:37 am
Bump
GTCRSHR
Postby solberg Fan » Fri Aug 19, 2005 9:12 pm
pot hole.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby GTCRSHR » Sat Aug 20, 2005 12:11 am
very productive
anyways on a more serious note
doing a little more investigating tonight
it now is squeeking when the clutch isbeing pressed in and out
so any more ideas ?
is there clutch fluid that i should be looking for/at ?
does any one know much about the clutch side of things of a ae101
gonna get it up on axel stands tomorrow so if any one has anything i should be checking it would be real help full!!!
thanks in advance
GTCRSHR
Postby GTCRSHR » Sat Aug 20, 2005 12:14 am
also ... if it is whats mentioned above
how do i go about fixing it ? am i in for a new clutch ?
GTCRSHR
Postby Akane » Sat Aug 20, 2005 1:34 am
if it's your throwout bearing, it's almost as much work as changing a clutch.
Postby sergei » Sat Aug 20, 2005 10:40 am
also, beter to do a full clutch job and main seal...
Postby GTCRSHR » Sat Aug 20, 2005 11:33 am
alright clutch job it is
how many km will this last and what can i do any other damage if i keep driving like this
or is it just gonna be annoying and no damage caused till i can get c;lutch done ?
thanks guys!
GTCRSHR
Postby GTCRSHR » Mon Aug 22, 2005 1:23 pm
bump :oops:
GTCRSHR
