Shock insert cooling oil
Postby ATAl » Sun Aug 14, 2005 11:17 pm
I'm about to put my shock shell / inserts together and have read that adding some oil inside the shell will help keep the insert temperature down by transfering the heat to the shell which is air cooled.
This makes a lot of sense to me but has anyone any experience with this - are there any problems? Should a certain type of oil be used? Should something else be used instead of oil?
ATAl
Postby THA SHZ » Mon Aug 15, 2005 11:10 am
motor oil dude 8)
THA SHZ
Postby Mr Revhead » Mon Aug 15, 2005 2:04 pm
first thing that comes to mind is youd want to be careful... if any leaks out you can fail a WOF for it.....
Postby bad20v » Mon Aug 15, 2005 2:10 pm
I never did anything like that when working at SAS rebuilding shocks. Like Warwick said; its more than likely to leak out between the shaft and the locking nut, causing you to fail a WOF as they will think its the insert leaking. As for cooling??? Are you put this car in an endurance race or something? If not, don't bother about it.
Thank-You.
bad20v
Postby ATAl » Mon Aug 15, 2005 2:34 pm
Just a daily driver - but if there were no side effects I would have done it, every little bit helps.
But it seems it would be more hassle with WOF than it's worth.
Thanks for the advise.
ATAl
Postby bad20v » Mon Aug 15, 2005 4:06 pm
No prob's. :D
Thank-You.
bad20v
Postby solberg Fan » Mon Aug 15, 2005 7:08 pm
Ive done it before. I was told that it can keep them quiet as well.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby solberg Fan » Mon Aug 15, 2005 7:10 pm
Ive done it before. I was told that it keeps them quiet as well. Eg stops banging noises if the insert happens to bottom out in the shell.
Team KB' Racing
1981 DX corolla
*My KE70*
solberg Fan
Postby Mr Revhead » Mon Aug 15, 2005 7:18 pm
the insert shouldnt be moving in the shell 8O
Postby NZ_AE86 » Mon Aug 15, 2005 7:47 pm
I always put some antifreeze in the strut body before assembling. This just helps to transfer any heat front the shock to the strut body. 8)
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby ATAl » Mon Aug 15, 2005 8:02 pm
Any problems with rust or leaking?
How much do you put in?
ATAl
Postby Mr Revhead » Mon Aug 15, 2005 8:05 pm
well antifreeze is a corrosion inhibitor..... and if it does leak, itll be easier to point out as not oil! so you shouldnt get pinged.
Postby NZ_AE86 » Mon Aug 15, 2005 10:19 pm
Never really had any trouble with leaking. And as Mr Revhead says, it will not rust as it is a corrosion inhibitor! Water would transfer more heat but could cause rust from the inside out!
Current rides;
1986 Levin GT
NZ_AE86
Postby ATAl » Mon Aug 15, 2005 11:27 pm
Yeah thought rust shouldn't be a problem but never hurts to double check
ATAl
Postby atmosports » Tue Aug 16, 2005 5:26 pm
Unless your shock is getting hot enough that you are doing damage to the seals or have a noticeable drop in shock performance even after the oil has cooled, anything you do to cool the shock is basically a waste of time. A shock is designed to get warm when running properly, & to be honest I doubt unless your racing or you have completely f**ked up valving you shocks will get hot enough to be off concern.
As for putting anything between the casing/insert, I've never done it even for race use when using inserts. But if you want to try then try, but make sure it's below the level off any seals etc on the insert as you do run a risk of contamination if the seals wear/fail.
atmosports
