So I need to replace the cracking S/C belt on my 4AGZE.
I have loosened off the centre lower ~guide pulley (it runs on a guide slot for tension). It logically looks like it should fall downwards, taking slack off the belt. It wont though, perhaps seized.
I've given it a light wack, but want to ask if this is correct prior to the big wack. I assume you don't have to loose this guide pulley from the front (centre of pulley wheel)
Any tips ?
thx in advance.
