how do i tell the diffrence between 4AGE'S?
Postby blackmk3 » Wed Aug 17, 2005 8:27 pm
hey guys just wondering...
how do you tell the diffrence between blue top (88kw) and red top (100kw) 4ages? i know the ovious is the cam covers....but im nt sure what to look for does any one have any pics or is there another way to find out?
red tops have T-VIS dont they?
Nick
Mk3 MA70 Supra
blackmk3
Postby fx gt » Wed Aug 17, 2005 8:36 pm
88kw will have tvis on the throttle body :)
fx gt
Postby trdfxgt » Wed Aug 17, 2005 8:37 pm
a 100kw red top does not have tvis also there is an external oil drain on the back of the head gear box side
trdfxgt
Postby Rick » Wed Aug 17, 2005 8:51 pm
Postby solberg Fan » Wed Aug 17, 2005 8:56 pm
I asked a similar question and this is what vvega wrote:
ok here we go
all bluetops are the same :
small cranks,3 rib block,bigport and tvis
red tops there 2 different versions
the tvis redtop and the non tvis redtop
the tvis redtop is basically a redtop bottom end with no squirters
the pistons are also a little different been lower compression
the head is a bluetop basically with a red color
they also use a 3 wire dizzy
the you have the real redtop
100kw
smallport
oil squirters
no tvis
4wire dizzy = true crank angle sensor
higher compression
there are more changes than i have noted but ive tried to keep it fairly basic in understanding
v
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby blackmk3 » Wed Aug 17, 2005 10:21 pm
Rick Posted: Wed Aug 17, 2005 7:51 pm Post subject:
http://home.clear.net.nz/pages/phil.bra ... %20RWD.htm
awesome link thanks very much everyone
exacly what i was after :)
Nick
Mk3 MA70 Supra
blackmk3
Postby Pelo » Wed Aug 17, 2005 11:02 pm
Someone make this a Sticky / FAQ !!!
Pelo
