20v lifter noise
20v lifter noise
Postby CEvans » Thu Aug 18, 2005 6:21 pm
does anyone have a problem with lifter noise in the ae111 blacktop 20v ,is it normal for abit or should it be checked if its getting noisey just asking cause someone told me that 20v were alittle noisier?
CEvans
Postby phatman3801 » Thu Aug 18, 2005 7:04 pm
they dont have lifters... it is quite normal for the vlave clearances to to slightly out whihc creates a ticking noise, u can get it fixed but its not worth it, i got my done and it just slowly came back and it cost a hole heap of money! ifs its not that bad dnt worry bout it
current project/ride: BZG levin
phatman3801
Postby Mr Revhead » Thu Aug 18, 2005 7:15 pm
could be the VVT pulley
Postby Xavier » Thu Aug 18, 2005 8:55 pm
is it during cold start or it is always noisy??? if it is always noisy, then it would be like Mr Revhead said, is the VVT pulley... if it is just the cold start and it went away when the engine is warm, it could be ur tensioner... :D
Cheers...
My Profile
1999 Altezza AS200 Z
1995 Trueno BZG (Previous)
1992 MR2 GTS (Previous)
Xavier
Postby CEvans » Thu Aug 18, 2005 11:01 pm
its noisey all the time wot does it consist of replacing the vvt pulley and how much?
CEvans
Postby Lloyd » Thu Aug 18, 2005 11:12 pm
Edited cause I didn't know what I was on about :D
Sorry, thought they came as a single part
Postby Mr Revhead » Thu Aug 18, 2005 11:16 pm
? wot you on about?
the cam is seperate from the pulley.
iirc around $300 for a new vvt pulley
Postby CEvans » Thu Aug 18, 2005 11:21 pm
k 300 for the pully and how much labour is involved in fitting it?
will engine run better with a new one?
any ideas on who is best for the job in wellington?
CEvans
Postby RedMist » Fri Aug 19, 2005 9:03 am
CEvans wrote:k 300 for the pully and how much labour is involved in fitting it?
About an hour, depending on how hard it is to get at the cam covers. You might want to do the cam belt at the same time.
No, in no way will it run better.
Not a clue.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Mr Revhead » Fri Aug 19, 2005 9:18 am
the only way itll go better is if the pulley has jammed. which does happen but is fairly rare
Postby CEvans » Fri Aug 19, 2005 9:24 am
so is it really necessary to replace the vvt pully or wait tile its worn abit more?
CEvans
Postby spencer » Fri Aug 19, 2005 12:54 pm
tensioner went in a blacktop I had made a violent noise when revved so maybe its the vvt pulley. I could see what it was straight away because rwd and no covers. When the pulleys go is it just the dampening fluid leaks out?
ms63 crown
spencer
Postby Mr Revhead » Fri Aug 19, 2005 12:57 pm
yeah the fluid leaks out and they sound like a diesel.
Re: 20v lifter noise
Postby ROBODISCO_20v » Sun Aug 28, 2005 1:31 pm
CEvans wrote:does anyone have a problem with lifter noise in the ae111 blacktop 20v ,is it normal for abit or should it be checked if its getting noisey just asking cause someone told me that 20v were alittle noisier?
Could just be a noisy injector, to the untrained ear it could sound like a tappet.
ROBODISCO_20v
Postby TrouserFxGt » Mon Aug 29, 2005 7:56 am
mine gets noisey injectors every now and then.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
