AE-101 4-AGE AFM
AE-101 4-AGE AFM
Postby Sanxta » Sat Aug 20, 2005 6:39 pm
Air flow meter (talking about the srew under the black, rubber cover to the right of the black section before throttle body) :
Who knows if it's clockwise or anti-clockwise to increase/reduce resistance to let more or less air through when the accelerator pedal goes down?
Cheers,
Sanxta
Sanxta
Postby sergei » Sat Aug 20, 2005 7:11 pm
does not work that way, if you are talking about the screw, it is there for idle fuel mixture adjustment.
Postby Sanxta » Mon Aug 22, 2005 12:42 pm
so what, clockwise for more fuel:air and anti-clockwise for less fuel:air?
sorta thinig?
Sanxta
Postby AceSniper » Mon Aug 22, 2005 6:33 pm
wind it out for more air to bypass the afm
AceSniper
Postby Mr Revhead » Mon Aug 22, 2005 7:40 pm
dont touch it
Postby LEV_101 » Tue Aug 23, 2005 10:06 pm
why not touch it. what does it do anyways ?
LEV_101
Postby Sanxta » Tue Aug 23, 2005 10:35 pm
AceSniper wrote:wind it out for more air to bypass the afm
wind it out = loosen?
yeah rev i'm a bit suss about playing with it, an AA mechanic reccomended i play with it if my car plays up . . .
Sanxta
Postby Jebus » Tue Aug 23, 2005 10:37 pm
Most probaly so youll have to take it back to him to get it fixed :P
Jebus
Postby Mr Revhead » Tue Aug 23, 2005 11:22 pm
yeah the toyota manual states they should not need touching once they leave the factory. why did he say to adjust it?
they are pretty much set at the factory on a flow bench
Postby spencer » Fri Aug 26, 2005 10:28 am
yep dont touch it it has that plug so you wont tamper with it. Theres no procedure to get it back where it should be
ms63 crown
spencer
Postby Mr Revhead » Fri Aug 26, 2005 10:31 am
well actually there is...
there is a number stamped next to it. thats the distance down the hole the top of the screw should be.
eg if its stamped 14. it should 14mm down.
but still best not to touch it
