4age turbo
4age turbo
Postby ants_ae92 » Tue Aug 23, 2005 2:56 pm
Hey guys,
Have recently canned my NA idea in favour of a 4age turbo. Have read many posts on here etc about how to go about it.(have searched too)
I have an ae92 small port block (and an ae92 fwd levin, currently with big port tvis), which I will use, replace with gze pistons.
What I want to know is how to go about it with either 4age distributor ecu etc, or using any other options (keeping in mind I dont want to grab all the gze stuff)? I know I should go after market, possibly link if I can.
Turbo wise I will probably look at a td05 either of a vr4 or evo.
So barring manifold design, oil and water feeds, exhaust, what can I do to control fuel and ignition timing?
Any advice guys?
Ants
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby crnkin » Tue Aug 23, 2005 7:45 pm
first tell us ya budget, and desired power levels, being realistic. For eg:
$500 will get you maybe 110-120kw atw
$2000 will get you about 140-180kw atw
$3500-4000 and you will start needing to upgrade boxes etc, but be looking at 250kw+ atw
All done the cheapest possible ways of course, then we can send ya the names of people who have gone down your path/budget :)
deaf_homo "currrently yes"
crnkin
Postby ants_ae92 » Wed Aug 24, 2005 8:50 am
Moderate budget at this stage, possibly $2000.
I have a rough Idea of cost, but the question i'm asking is 4age turbo, not 4agze turbo which is my main problem?
And at this stage possibly just 110-120kw - low boost (still doing gze pistons) at the moment, but want to upgrade in the future?
ants_ae92
Postby Jebus » Wed Aug 24, 2005 2:27 pm
Thats easy, have a browse over these.
http://garagedori.com/members/mattg/AE86_mk2/index.php
http://garagedori.com/tech/4age_btecu.php
http://garagedori.com/tech/turbo86/turbo.php < read all the pages of that.
Garage Dori is the place to go for that kind of info, have look around and check the forums.
Jebus
Postby crnkin » Wed Aug 24, 2005 2:35 pm
yep thats right
Look at karl skewes and matt gills past set ups
For 2g youll be looking realistically at 170-190kw atw
Assuming:
-Cheap manifold (300 bucks)
-cheap link ecu (maybe 600)
-Link Tuning (3-400)
-Oil lines, intercooler, putting together (3-400)
-t3/4 or t28 turbo (2-400)
-385-440cc injectors (100)
remove tvis and get tuned professionally, the best power you can get is from the tune
If you run a redtop bottom end and a mild p+p, gze pistons (maybe an extra 1000-1200) you can get like 200-250kw atw, so for your budget id just look for the individual bits, then work up a good stock engine, will last years with a good tune and regular servicing
go hard, im looking at doing the above mods to a stock fxgt, 190kw atw should net 12's, be phat :)
crnkin
Postby Mr Revhead » Wed Aug 24, 2005 2:39 pm
8O knock ya piston price3 in half there man, youll give ppl heart attacks!
Postby ants_ae92 » Wed Aug 24, 2005 2:51 pm
Yeah I have read their pages, looking at it now, it might just be easier to get the gze computer and afm, loom, cas,coil packs and ignitor and then use that as a base.
Who knows what i'll do.
Definitely going for gze pistons, will keep researching as you do
ants_ae92
Postby luvnit » Wed Aug 24, 2005 5:35 pm
hey ive been wanting to do this for some time as well, money and insurance being the only things holding me back, ive got AE101 but its only running a 4afe, so what would be the best bang for buck/cheapest option replacing the engine for a 4agze or replacing the pistons for stronger items from a 4agze and a 20v head im wanting around the 170kw - 190kw atw
i want a turbo, why not 2... new car
1993 mitsubishi galant vr4 TT
now with a poked rear diff
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1464 - updated with new car
luvnit
Postby ants_ae92 » Wed Aug 24, 2005 5:47 pm
get any 20v block or 16v small port - they have the same internals barring the pistons. Replace pistons with 4agze items.
4afe rods may not hold up too well and I think the block specs are different to 4age right?
20v's are cheap enough and easy to find.
ants_ae92
Postby luvnit » Wed Aug 24, 2005 5:49 pm
i think the blocks are the same, the only difference im aware of is the the cams are only 22. 5 degrees instead of i think 46 degrees in the 4age which is why i want to change them
luvnit
Postby luvnit » Wed Aug 24, 2005 5:54 pm
does anyone know if the head from a AE111 blacktop will fit on to a 4afe from a AE101
luvnit
