Swapping 2E for a 4E
Postby DVLRCR » Tue Aug 23, 2005 8:11 pm
hey guys. i killed my 2E.
how much work do i need to do to replace it with a 4E?
i heard it would bolt up but i'd need to mod the exhaust?
any help appreciated!
DVLRCR
Postby DVLRCR » Wed Aug 24, 2005 10:15 pm
Bumpidy bump. still looking for some info...
DVLRCR
Postby dotdog » Wed Aug 24, 2005 10:20 pm
What sort of 2e to what sort of 4e, cause if you want to go from a 2e-c to a 4efte or 4efe there is alot of work involed
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby DVLRCR » Thu Aug 25, 2005 7:30 am
i dont know what it is. its a carbed 2E. not sure bout the 4E to be honest. but apart from wireing, throttle and that sorta stuff, what's needed?
DVLRCR
Postby dotdog » Thu Aug 25, 2005 6:50 pm
Um, well you will have to use a injected 4e cause i dont think they make a carby one, not sure tho, just chuck another 2e back it, way easyer and cheaper
dotdog
Postby 86_rolla » Thu Aug 25, 2005 7:37 pm
depends on want, if you want more grunt and got the cash to spare why not put a efte in there, people say its easier to chuck a 4efte than a 4age. Wasnt there a 2e-t?
86_rolla
Postby dotdog » Thu Aug 25, 2005 7:47 pm
Yip, im runnig a 2e-t
dotdog
Postby 86_rolla » Thu Aug 25, 2005 7:54 pm
pretty hard to find those engines aye?. would it be easier for someone to bolt in a 2e-t or a 4efte?
86_rolla
Postby dotdog » Thu Aug 25, 2005 8:05 pm
Hmm, bout the same, but 4e's are more common, more powerful, easyer to get bits for
dotdog
Postby DVLRCR » Thu Aug 25, 2005 9:13 pm
ive been offered a 4E for a good price, less then i can get a 2E for. so what needs changing?
DVLRCR
Postby Jebus » Thu Aug 25, 2005 9:56 pm
You current gearbox/mounts should be fine, youll need it wired $500+ if you cant do it yourself, mounting and piping of the intercooler (im assuming its 4efte) a high pressure fuel pump, maybe a surge tank, a bigger feed line and your stock line can be the return for the EFI. A whole new exhaust system. Youll need a cert, and your brakes and susp may need a bit of a refresh/upgrade. Then theres the usual expenses.
If your gunna do it properly budget over $5g's
so 2E + little or no extra cost vs 4EFTE + $5+ grand
Jebus
Postby Rob » Thu Aug 25, 2005 9:57 pm
4E will bolt in and they do come out carbed. I did 3E-4E conversion at work a few weeks ago manifolds are different so you might be able to swap the carbs and give it an engine flush cause they prone to shitting themselves
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby 86_rolla » Thu Aug 25, 2005 10:57 pm
i didnt think it would of cost 5g, just outta curosity how much prcentage of that would be labour costs?
86_rolla
Postby Jebus » Thu Aug 25, 2005 11:01 pm
Not alot of that would include labour. Have you done a major carby to EFI conversion. It may seem simple but it all adds up very fast. This being why so many projects get left unfinished. i.e people budget say $2k for a 4age conversion, that gets them a motor, gearbox, mounts, buys some missing parts then theyre broke with, the wiring, exhaust, unexpected problems, cert, all the maintainence parts for the motor. It all adds up, ask anyone whos done a big engine conversion.
Jebus
Postby 86_rolla » Thu Aug 25, 2005 11:36 pm
yeh, no never done one, i was just wondering because i am in 2 minds weather to keep the 2E cause its so cheap on fuel or do a conversion, i jst didnt expect the bill to be that big.
86_rolla
Postby Jebus » Thu Aug 25, 2005 11:39 pm
Yeh, the general rule, take your budget and double it and youll be about right.
Maybe get another shitter rolling body you can hack away at when you have the cash, cos a reliable economic daily driver is really handy.
Jebus
Postby DVLRCR » Fri Aug 26, 2005 7:54 am
jebus, thanks but this isnt my project man! as you can see in my sig, i have a real car to work on and this is my daily hack. as in a car that has more empty bottles of coke and V then a recycle bin and more fast food wrappers then a fast-food-wrapper-storage-facility-cupboard place at a fast food thingy :P
and i doubt its turbs or anything! i'm getting it for FREE! so it will most likely be the crappiest one. which i presume is the carbed version. if so, what do i need to change? i know the whole thing will bolt in. but what about the exhaust manifold? what needs changing there? how about clutch etc? i guess thats all the same...?
thanks for your help so far guys!
also, to add to jebuses comment about the price of a conversion, and doubleing the price... he's right! also, double the time you are thinking you'll need and that might get you a close estimate :P
DVLRCR
Postby SIKTOY » Fri Aug 26, 2005 8:32 am
Rota it. :lol: :lol: :lol:
If you did Id murder you :twisted:
You and your cheap engine conversions. :roll:
Dont blow your gearbox this time. :wink:
L8a
ALL MEN DIE, NOT ALL MEN TRULY LIVE!
Current: 80 SR Project,
Check Out My Profile, Including CURRENT Pics!
Previous: 90 GT Sedan, 85 FXGT, 77 SR with 18RG, + many more.
Pink shaved pussy pic!!!
SIKTOY
Postby Rob » Sat Aug 27, 2005 7:04 pm
For a 4E you will have to change the exhaust flange but the clutches Im pretty sure are the same
Rob
Postby QikStarlie » Sat Aug 27, 2005 7:09 pm
all 4e's are injected. so it wont be carb'd, only the 12v's (1e, 2e, 3e) come out carb'd
QikStarlie
