MR2 Question w PIC
MR2 Question w PIC
Postby mister_two » Thu Aug 25, 2005 2:09 pm
Is this the air temp sensor? wat if u turn it clockwise or counter clockwise?
not sure wat it does, any help wud be appreciated
http://au.pg.photos.yahoo.com/ph/angel_ ... pg&.src=ph
mister_two
Re: MR2 Question w PIC
Postby anthonym » Thu Aug 25, 2005 3:22 pm
mister_two wrote:Is this the air temp sensor? wat if u turn it clockwise or counter clockwise?
Aircon idle-up valve, not sure what your question is. If you mean adjustment screw, it would vary the idle assistance. If you mean the valve itself, orientation should have no effect.
anthonym
Postby mister_two » Thu Aug 25, 2005 3:47 pm
thanks anthony, yeah was playin with it a bit, it actually varies the idling, do u normally have this all the way close or open?
thanks again :)
Nan
mister_two
