small port vs. big port head
Postby Lamphant » Fri Aug 26, 2005 5:25 am
which one of these 2 toyota engine head designs, do you guys use when t'charging and stuff and in ur opinion which is best suited for t'charging and NA.
to me i would go with the big port head, because it allows more air into the engine, but only slower than the small port head, which flows less air but faster.
so which of these to heads are best suited for NA/ t'charged applications and what are y'all views on them
Lamphant
Postby crnkin » Fri Aug 26, 2005 10:03 am
its been covered alot of times, but as for stock id be inclined to go bigport, but to spend money and get p+p's etc, youd probly want to start with the smallport, and get some real nice ports machined in, real nice cuts too.
Ill be running smallport, but have been in many bigports which go hard
its all about the money i guess!
deaf_homo "currrently yes"
crnkin
