Hi All !
I put bigger cams on a friend ST202, and I know it would happen, idle is steady only if I set it to 1500/1600 rpm.
Lift at TDC is:
intake 1.0mm - exhaust 0.8mm
Is there any other possibility to have a better/lower idle without going for an aftermarket ecu ?
Reduce a bit the overlap, for example turn the intake lift at TDC to 0.8mm ?
Increasing fuel pressure ?
Any other idea ?
Thank you !
