toyota part number on 02 sensor for blacktop????
Postby phatman3801 » Mon Sep 05, 2005 9:50 am
has any one got an o2 sensor from an ae111 black top luying around and can tell me the toyota part number on it? as i have been given a senond hand one from the ehaust place the lost mine but i still dont trust them when they say it was frm a blacktop...
current project/ride: BZG levin
phatman3801
Postby Mr Revhead » Mon Sep 05, 2005 1:56 pm
89465-19685
Postby phatman3801 » Mon Sep 05, 2005 3:35 pm
the one they gave me is: 89465 - 12440 wots that for?
phatman3801
Postby Mr Revhead » Mon Sep 05, 2005 3:39 pm
comes up as unknown part number.
which means either youv got the number wrong.
or its one thats never been ordered into nz and never priced.
it doesnt show ont he epc, but if its a superceded part number it may not
Postby phatman3801 » Mon Sep 05, 2005 4:39 pm
hmm thats deffintly the number on it! it plugs up perfect to the socket on the loom and fit the flandge on on pipe mint, do they make just one type of 4 wire to bolt flange sensors or are there lots of toyota ones that phyisally look and fit the same but read different?
phatman3801
Postby Mr Revhead » Mon Sep 05, 2005 4:41 pm
there are probably several that look the same
as for how they read.... too hard for me im afraid
Postby phatman3801 » Mon Sep 05, 2005 5:14 pm
hmmm that makes things tricky then, if any one has a sensor out of there blacktop can they please post me tyhe part number on it
phatman3801
Postby Bling » Mon Sep 05, 2005 8:35 pm
is the car still driveable? if so why does it matter :P
Postby phatman3801 » Mon Sep 05, 2005 8:38 pm
it matters as with the wrrong sensor it wont adjust the air fuel raitos correctly and could be runnning rich or lean which could cause possible long term engine damage..
phatman3801
Postby aesc » Mon Sep 05, 2005 8:44 pm
Not necessarily, the o2 sensor only adjusts the mixture when idling or light load ie crusing. When moderate to heavy accelerating or decelerating etc, the ecu goes into closed loop which means that the input from the o2 sensor is not used.
If the plug fits then it should work fine. All narrow band sensors work on the same principle, providing the ecu with 0-1V based on lean-rich mixture so id say the one you have will work sweet. Its gotta be better than not having one at all
If your worried about getting the right one, why dont you go to pick-a-part or whatever it is and get one off a wrecked ae111
EX AE101 owner
2013 Ford Focus ST
aesc
Postby phatman3801 » Mon Sep 05, 2005 8:47 pm
i live in gisborne and there are defintly no ae111s at a wrekers..thats y i was hoping sum on the forum would be able to tell me the part number on theirs so i can confrim i have the right one
phatman3801
Postby Bling » Mon Sep 05, 2005 9:09 pm
where is it located, i'm working on the car this weekend, put up pix and i'll have a look
Postby phatman3801 » Mon Sep 05, 2005 9:14 pm
the part number is on the brownie coulour bit before its gos to the wires, ill take i pic of the sensor 2moro
phatman3801
