any advice/info/suggestions welcomed
Distrb wrote:Personally i wouldnt look at one that wasnt Beams 4cyl and 6spd manual, but then again, it comes down to why you want one... (but since i own one, i would say that, wouldnt i?)
Cons
- throttle response isnt terribly great on factory spec one (manual only)
anthonym wrote:Cons
You mean poor torque at lower RPM, not throttle response.
Toyota NZ website wrote:GRADE BODY SHAPE ENGINE TRANSMISSION DRIVE
AS 200 Sedan 4dr 1G-FE 4A Rear
AS200 Z ED Sedan 4dr 1G-FE 4A Rear
RS 200 Sedan 4dr BEAMS3S-GE 6M/5A Rear
RS200 Z ED Sedan 4dr BEAMS3S-GE 6M/5A Rear
AS200 L Ed Wagon 5dr 1G-FE 6M/4A Rear
AS200 Z Ed Wagon 5dr 1G-FE 6M/4A Rear
AS300 L Ed Wagon 5dr 2JZ-GE 5A/4A Rear/4WD
AS300 N Ed Wagon 5dr 2JZ-GE 4A 4WD
Engine
MODEL CM³ FUEL TYPE POWER (KW) TORQUE (NM)
1G-FE 1988 P DOHC 24 valve VVT-i 118/6200 200/4400
BEAMS3S-GE 1998 P DOHC 16 valve Dual VVT-i 154/7600 216/6400
2JZ-GE 2997 P Twin Cam Six VVT-I 162/5600 300/4000
SIKTOY wrote:Another thought to consider (if you care) is that the sedans have 6.5" fronts and 6x9's rear from factory. They arent the best, but decent for factory speakers. Plus lots of space in factory (ie optimum) posistions, for a wikid upgrade.
The RS200Z is the best of the 2L lot, but needs revving to get down and boogie. & Manual is a must unless your going 2JZ.
