Engine Break in....
Engine Break in....
Postby RomanV » Thu Sep 08, 2005 2:35 am
I came across this article, which I found interesting.
http://www.mototuneusa.com/break_in_secrets.htm
Some of his other articles were quite interesting too. 8)
Although his writing style and web page skills leave a lot to be desired. :lol:
Postby Ae92typeX » Thu Sep 08, 2005 11:03 am
Interesting article. Not too much different then my mr2 manual says though really- that also says to warm up then do some full throttle runs/ closed throttle slow downs 10-12 times, then to drive gently (Just no sustained high speed) for the first 500 miles.
Ae92typeX
Postby Caveman » Fri Sep 09, 2005 10:51 am
Also with new cams or freshly reground cams its important to start the engine on the first 2-3 strokes to properly work harden the cam.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby KinLoud » Sat Sep 10, 2005 8:47 am
Yes - any time I have had to fly a piston engined aircraft with a new engine just fitted. The engineer says "don't muck around on the ground too long, takeoff and use 100% power for the first 20 minutes, then 80% for the next 40 minutes"
For the first 50 hours of flying the new engine should be used on navigation flights using 75% power. After that the aircraft can do circuits and all the other lower powered flying that occurs in flight training.
Also - they use mineral oil for the first 50 hours before switching to synthetic.
Ken
Ham
021 408 863
