4agze fuel pump?
4agze fuel pump?
Postby TurboAE85 » Tue Sep 13, 2005 4:37 pm
Can these pumps supply enough fuel for 300hp?
TurboAE85
Postby Bazda » Tue Sep 13, 2005 4:42 pm
personally I dont think they can...
i would go with a S4 rx7 one, direct bolt in.
Postby TurboAE85 » Tue Sep 13, 2005 4:45 pm
Cheers mate :)
TurboAE85
Postby Drifter4ag » Tue Sep 13, 2005 6:56 pm
stock AE86 bluetop pump can supply enough for 300hp so no reason why a 4agze one cant unless they stuck a budgyone in the GTZ
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby Bazda » Tue Sep 13, 2005 7:02 pm
both I an IH8TEC couldnt get enough fuel from the stock gze one :roll:
Postby sk1dlet » Tue Sep 13, 2005 8:20 pm
i have a series 4 intank pump name a price?
sk1dlet
Postby sergei » Wed Sep 14, 2005 9:09 am
I don't know about part number, but AE101 GZE pump looks exactly the same as AE101 20v....very small.
Postby Bazda » Wed Sep 14, 2005 10:23 am
they all look the same, the rx7 one looks the same so does a evo one, but they have different part numbers on it.
Postby Drifter4ag » Wed Sep 14, 2005 12:27 pm
the ae86 one is about double size on an evo one .. and is very noisy and will between 2.4-2.6litres per min .. which can cater to some big injectors ;) ... possibly the FWD bluetop gear is the same .. ie ae82 etc
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby suberimakuri » Wed Sep 14, 2005 1:39 pm
I have evo pump if you need one, pm me your offer.
suberimakuri
Postby wanado13's » Thu Sep 15, 2005 10:39 am
I had a look at your pump on trade me sk1dlet and it says it doesn't have a sender unit, u've done the swap bazda and is this needed? Also by putting one of these pumps in but keeping the lines and injectors standard is there much point?
wanado13's
Postby Bazda » Thu Sep 15, 2005 10:54 am
I had an extra injector controller, so it had to get more fuel from somewhere.
I was using half of a 740cc injector. So I was running about 440cc+ through each cylinder.
Have u seen those warlbro 255L pumps, they are smaller than the 4agze pump 8O but flow heaps.
All you need is the pump it self, it will just bolt in.
Postby wanado13's » Thu Sep 15, 2005 2:19 pm
cool thanks for that, do you know the l/hr rating on s4 pumps?
wanado13's
Postby sk1dlet » Sun Sep 25, 2005 4:20 pm
na that can't have been my pump i haven't had it on trademe
sk1dlet
Postby JamesM » Sun Sep 25, 2005 8:45 pm
i have 350l/hr pump and its twice the size of walbro ones :)
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby ants_ae92 » Mon Sep 26, 2005 12:58 pm
Drifter 4ag: What about other 4age fuel pumps, are they the same as the ae86 blue top ones?
I have an ae92 redtop tvis one, will it flow the same as the ae86 blue top one?
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby Drifter4ag » Mon Sep 26, 2005 4:00 pm
dunno...
its a funny pump in the ae86 ... all people i know have not changed fuel pumps for large power levels .. onJDM import cars only.
I assume that ae82 FXGT is the same. But i wouldnt quote me on that
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
