celica 2nd gear problem
Postby JASON_SHEMAN » Tue Sep 20, 2005 9:51 pm
i just read some information from oversea forum, they said the st182 celica always have problem on getting into second gear....and they suggest to use "pennzoil syncromesh" gearbox oil....
does this oil avaible in nz? anyone try it?
JASON_SHEMAN
Postby AJz » Tue Sep 20, 2005 10:05 pm
im on my second gearbox if that helps :P
do you have problems goin into 2nd? Upchanging or downchanging, Is it a crunch or just stiff?
I had vtax :(
AJz
Postby JASON_SHEMAN » Tue Sep 20, 2005 10:16 pm
it crunch both Upchanging and downchanging into second..
JASON_SHEMAN
Postby JASON_SHEMAN » Tue Sep 20, 2005 10:18 pm
http://www.celispeed.com/forum/about8092.html
here the link of other forum which i found the information!
JASON_SHEMAN
Postby AJz » Tue Sep 20, 2005 10:20 pm
how fast are you changing from 1st to 2nd, like raping it or just normally. Is this once the car/engine/gearbox is warm? or right after starting from cold.
I had the same problem with you, its the syncros, toyota never built our boxes with strong enuff syncros so its quite common to find these with fuked boxes. I was needing to replace my clutch at the same time so with the price of putting in new syncros etc. i just bought a 2nd hand average condition box, and got that put in, along with the new clutch kit etc.
I had vtax :(
AJz
Postby JASON_SHEMAN » Tue Sep 20, 2005 10:24 pm
it happened after the engine warm up.....i change gear from first to 2nd around 3200rpm.....
but if i press the clutch and keep it like 1 second, them put into 2nd gear, it's fine
JASON_SHEMAN
Postby AJz » Tue Sep 20, 2005 10:31 pm
o ok, mine didnt do that, only on downchanging, but yea, long term, putting in another box is the cheapest option, they arnt hard to find.
I had vtax :(
AJz
Postby JASON_SHEMAN » Tue Sep 20, 2005 10:39 pm
THX AJZ
JASON_SHEMAN
Postby Boosted_162 » Wed Sep 21, 2005 1:41 am
My old ST162 went through a couple of boxes, one i blew the box and diff (go me!). The price to replace synchros was something stupid like $400 for 1 synchro!! Just get a new box, alot easier in the long run.
Postby NZcelica » Wed Sep 21, 2005 12:33 pm
Yep I blew 2 2nd gears in my ST162. Try and find a ST171 GT-R box, they appear to be less thrashed and are better. Or ideally an SV32 GT box, these have longer ratios and are stronger 8)
But yeah, cheap option, fill gearbox with marmite :lol:
Or just get a replacement box :)
ST165 Celica GT-4 <SOLD>
97 GT-T 18psi <GONE>
96 Carib BZ 5 speed
Looking to import a car? PM me
Lots of performance Toyotas forsale. PM me for details
NZcelica
Postby JASON_SHEMAN » Wed Sep 21, 2005 6:13 pm
st171 and sv32 gear box can fit my st182 straight away? how about st191 cornoa? is it the same box..
and the longer gear ratio, it is means accelerate slower??
thx
JASON_SHEMAN
Postby AJz » Wed Sep 21, 2005 9:22 pm
longer gear ratio means it has longer gears, hence being able to do what you could do in 2nd when with the stock box you were already in 3rd.
I had vtax :(
AJz
Postby JASON_SHEMAN » Wed Sep 21, 2005 10:37 pm
so, will it accelerate slower???
JASON_SHEMAN
Postby CozmoNz » Wed Sep 21, 2005 10:39 pm
Yeh, my god, Nzcelicas old ST162, on the dunedin -> chch drive, i found myself sitting in 4th accidentely (120kph), at around 3500rpm, (i think), which i was expecting from 5th...
till he taps me on the shoulder *hey bud, ya got another gear*.. well fk me!
Rayne For President!
CozmoNz
Postby JASON_SHEMAN » Wed Sep 21, 2005 11:03 pm
but i m thinking like the close ratio gearbox with accelerate faster than the normal gear ratio gearbox
JASON_SHEMAN
