S series Rear end brake options
Postby Jebus » Wed Sep 21, 2005 1:25 pm
What options are there for bolt on brakes to an S series diff housing from an AE70/AE85 mine has no brakes, what are the bolt on options other than the standards, I dont have the complete drums from the diff. Im not fussed on either drum or disk.
My stock KE30 drums have been reco'd can these be used?, or do I need AE85? Also are AE86 drums and bigger than ae85 and are they a direct fit?
Jebus
Postby fangsport » Wed Sep 21, 2005 6:57 pm
AE86 are disc not drum and if i was Bad20v i'd be going BAHAHAHAHAHAHAHa, but i'm not, so I won't.
try the the KE30 backing plates to see if they fit the bolt spacing on the axle tube, and also check whether the bearing fits through the hole in backing plate.
KE70 might be the same as AE85. been a while since i mucked around with drums ,sorry.
there are ways to disc brake the rear but can be costly.
fangsport
Postby Jebus » Wed Sep 21, 2005 7:51 pm
Didnt 86's come with drums too?
Jebus
Postby z|gen » Wed Sep 21, 2005 8:17 pm
te71 came in both disc and drum
AE91 SUPERCHARGED COROLLA
z|gen
Postby fangsport » Thu Sep 22, 2005 9:06 am
Jebus wrote:Didnt 86's come with drums too?
i suppose, when you consider the aussie version being badged as an 86, but in all due respect, is has more in common with the JDM 85.
fangsport
