AE101 vs AE92 GTZ LSD driveshafts
Postby TurboAE85 » Sun Sep 25, 2005 7:18 pm
Wondering what the legnth differences are between AE101 and AE92 GTZ LSD driveshafts are? and which ones will be most suited for my AE82 FXGT which has a 4agze with LSD gearbox in it and will be lowered. Do the shafts need machining?
TurboAE85
Postby Bazda » Sun Sep 25, 2005 9:32 pm
what did u get ur box from, ae101 gtz or ae92 gtz?? get the axles from what ever car the box is from
Postby gtcielo » Mon Sep 26, 2005 7:24 pm
Bazda What did u end up using and whats diferent between the 2?
4agze turbo
gtcielo
Postby Bazda » Mon Sep 26, 2005 7:27 pm
i got a ae101 gtz box, had to use teh passengers side shaft, but used my standard non lsn shaft for the drivers side, had to shorten that 3mm where the shaft goes into the box and also put a chamfer on a certain part of the shaft so it would seat properly when I put it in.
