4AGE MAP sensor Outputs
Postby Jebus » Wed Sep 28, 2005 9:12 pm
What is the range of voltages outputted by a 4AGE MAP sensor if anyone knows? Cheers
Jebus
Re: 4AGE MAP sensor Outputs
Postby matt dunn » Wed Sep 28, 2005 10:55 pm
Jebus wrote:What is the range of voltages outputted by a 4AGE MAP sensor if anyone knows? Cheers
They have
5V feed
Earth,
and signal,
so the ramge of output is 0 to 5V.
In reality though and due to electronics in the the actual range is more like,
0.5V to 4.5V.
Postby Jebus » Thu Sep 29, 2005 7:29 am
Perfect, thanks dude.
Jebus
Postby ants_ae92 » Thu Sep 29, 2005 8:47 am
Does anyone know what the output of the map sensor is when it hits 4psi boost cut?
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby matt dunn » Fri Sep 30, 2005 10:27 pm
ants_ae92 wrote:Does anyone know what the output of the map sensor is when it hits 4psi boost cut?
The NA sensors wont go to 4 psi? What ones are you meaning?
Postby ants_ae92 » Mon Oct 03, 2005 8:14 am
Was meaning the 4age map sensor. Karl skewes and the garage dori boys seem to reckon a standard blue top ecu will fuel it fine to 4psi then hit fuel cut, so the map sensor must be getting a reading at that pressure?
Or would it just dump all fuel possible into it and read 5v?
I was going to do a small bolt on turbo this way on an ae92 4age
http://forums.toyspeed.org.nz/viewtopic.php?t=31816&highlight=
ants_ae92
