What spark plugs for a 4agze?
Postby lil » Fri Sep 30, 2005 10:21 pm
I'm looking to change the spark plugs in my supercharged mr2 and was wondering if anyone has had any experience with the various types and heat ranges.
What is the best option for a stock engine?
lil
Postby Lloyd » Fri Sep 30, 2005 10:48 pm
The stock plugs strangely enough. NGK BCPR6EYs from memory. Whatever plugs are listed for them, heat range of 6 anyway
Postby peas » Sat Oct 01, 2005 8:12 am
My old GT-Z Levin had a small miss in its top end rev range which was cured by replacing the plugs with NGK platinums. I expect even replacing with standard NGK R plugs would've helped as well though but I run platinums, don't cost me a hell of a lot through work.
'97 Caldina GT (ST215G)
peas
Postby overcast » Sat Oct 01, 2005 9:06 am
Just be careful. I work in the Automotive parts industry and some applications you have to use a platium or similar plug. Go to www.ngk.com and that will tell you what options you have.
The advantage of Platium (being replaced by the iridium range in ngk) plugs is that you dont have to change them as often as a standard plug (approx every 100 000 km)
overcast
Postby EVLGTZ » Sat Oct 01, 2005 11:15 am
The std NGK version of the platinum plugs for the 4agze are fine. Use them if ya aint got the cash or fork out for platinums if ya really want to but apart from lasting a fair bit longer there is no real dif.
I'd just run NGK BCPR6ES which i think is the correct code for std heat range and non-platinum
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby ROBODISCO_20v » Sat Oct 01, 2005 12:01 pm
overcast wrote:The advantage of Platium (being replaced by the iridium range in ngk) plugs is that you dont have to change them as often as a standard plug (approx every 100 000 km)
Iridium plugs only last 60 000km
NGK is not replacing platinum with iridium, they are running both lines & aiming the iridium plugs at the preformance market. Platinum plugs still have thier place in the market as a long life plug.
NGK dont currently don't do an iridium option for the 4AGZE. The standard platinum plug for all ZE's is BCPR6EPN8
ROBODISCO_20v
Postby Mr Revhead » Sat Oct 01, 2005 2:59 pm
actually its a denso pq20r
NGK bcpr6ep
Postby beeker » Sat Oct 01, 2005 5:36 pm
Mr Revhead wrote:actually its a denso pq20r
NGK bcpr6ep
I need new plugs for the Targa car, 4agze. Obviously they'll get a hiding (within stock ECU Limits though). What is recomemnded for this type of use ? PN would be ideal please.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Pelo » Sat Oct 01, 2005 6:41 pm
ROBODISCO_20v wrote:NGK dont currently don't do an iridium option for the 4AGZE. The standard platinum plug for all ZE's is BCPR6EPN8
According to my 2005-2006 NGK catalog right here,
The standards for 4AGZE are BCPR6ES-11s, BCPR6EIX-11s for Iridium, and BCPR6EP-11s for platinum (11 being 1.1mm gap.)
I run BCPR6ES gapped to 0.9mm in my car, my theory was I might get spark blow out at 14psi but it doesn't seem to make any difference, so when I can be bothered pulling them out again I'll put them back to 1.1mm...
Also Iridiums made no noticable power difference compared to new copper plugs.
Pelo
Postby beeker » Sat Oct 01, 2005 6:48 pm
which are better at hi temp ? or consistent hi temp ?
06 RS4 Avant
beeker
Postby EVLGTZ » Sat Oct 01, 2005 7:22 pm
Pelo wrote:According to my 2005-2006 NGK catalog right here,
11s? I thought they were all 8s as in 0.8mm gap. I and everyone else I know with 4agzes have always run that.
Catalogue prob wrong :?
EVLGTZ
EVLGTZ
Postby matt dunn » Sat Oct 01, 2005 7:24 pm
My thoughts too.
we never run 1.1mm gap in anything turbo'd
Matt
Postby auch » Sat Oct 01, 2005 7:31 pm
bro i highly recommend bosch super 4 spark plugs. i have heard lots of positive comments already. just look it up on trademe...
auch
Postby Al » Sun Oct 02, 2005 1:10 am
auch wrote:bro i highly recommend bosch super 4 spark plugs. i have heard lots of positive comments already. just look it up on trademe...
Bosch Super 4's are the biggest gimmick.
The Denso plugs listed by Mr Revhead or even a set of copper ngks will be fine. I run el cheapo ngk bkr7e's $20 for four.
Al
Postby matt dunn » Sun Oct 02, 2005 1:18 am
We sell bosch plugs at work.
They are good plugs and are well suited for certain applications,
(ie anything aussie made). Would not fit them to a Japanese designed/built car.
you will find the sometimes up to 15 different NGK plugs will all cross over to one single bosch plug, they just dont have the range.
Whatever you do don't fit cheap champions from repco or similar.
Run NGK or Denso.
Postby ROBODISCO_20v » Sun Oct 02, 2005 1:51 pm
NGK bcpr6ep
I didnt mean standard from factory, i ment the standard listing from ngk. NGK list platinum plugs for all 4AGE 16/20valve & ZE.
As for 1.1mm gaps in ZE's i think Pelo is looking at the GE listing. Every NGK catalogue I've looked at has listed 0.8mm gap for ZE's
To answer Beeker's question a colder temp will be better for prolonged hi temps like racing. So you could safely run a BCPR7ES gaped down to 0.8mm. In most street 4AG's 7's will foul up as they spend to much time a lower revs
ROBODISCO_20v
Postby suberimakuri » Mon Oct 03, 2005 3:43 pm
I used to run something like BCP8ES on my 4age turbos. good plugs.
suberimakuri
Postby JamesM » Mon Oct 03, 2005 8:54 pm
anyone tell me if the blitz spec 77 iridiums are any good? what r they equivalent too? for some reason i bought them a while back
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby suberimakuri » Tue Oct 04, 2005 9:39 am
drifter4ag has some blitz iridiums, seem to work really well.
I think his are equivalent of 8's.
suberimakuri
