hey guys a mate of mine just got his 1.8 vtec integra engine tuned with a link and the guy set it to 9200 rev limit. The engine is NOT a type r model and has standard everything bar intake and zaust. Does this sound a little high to you guys?...
Dont want my mate blowing up his new toy as he's one of the only honda drivers i know who's actualy a really nice guy
"The air is heavy with antisipation as cozmo revs, drops the clutch and...... stalls with the hand brake on"........ "cozmo's hand brake one, cozmo 0"
I'm unfamilar with those engines. However that piston speed is really getting up there. Remember that the Link cuts fuel 200 rpm before the limit, and if your anything other than stupid you button off or change on the first falter at 9k.
If your friend is after engine longivity that RPM limit is certainly not the way to go about it.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
Sounds a bit high, even the Gizzmo chips (which IMO have too high a rev limit for most applications) set it at 8500. Just borrow a hand controller and bring it down, its not hard to do.
1988 KE70 Wagon - Slowly rusting 1990 NA6 MX-5 - because reasons 2018 Ranger - Because workcar 1997 FD3S RX-7 Type R - all brap, all the time OMG so shiny!
standard everything? no idea how strong those are, but itll be falling waaaay off the power long before then.
id say factory rev limit would be the best to use.
do a dyno run, see what happens to the torque curve, then use that as a guide. but id be pretty nervous taking my stock engine to 9k
Dont the mugen chips let you rev out to 10k Mate had a four door b18c teg, it wasnt all that workd but im sure he said the chip would let it rev to 10...Im not so sure on how good it would be for it...
I've had 2 VTEC's that I was in charge of driving nearly daily for a year or so each, and they pretty much lived on the 8200rpm (?) rev limiter, one was a B18, other B16, and they $$% loved it...
I've got 9k cut on my silver top, had it for 2 years hit a few times on meremere, it is not a soft cut BTW, feels like fuel cut. It is lazy after ~7000 anyway. If I do shifts just before 9k I will have slower times, then if I do at 7600-7800... + I don't know about honda but with toyota sychros don't like to engage properly at very high rpms anyways...
