4af manifold
4af manifold
Postby tenyearguarantee » Tue Oct 04, 2005 2:13 pm
I have a trusty ol toyota corrola with a 4af. Wondering if there has been a manifold made sutible to fit twin carbs onto.
tenyearguarantee
Postby atmosports » Wed Oct 05, 2005 5:14 pm
Yes there is a 4AF dual side draught manifold available. I don't however have any idea on the price as it's not one I've ever made or stocked but if you are really keen I could get a price etc which I'm guessing new would be around the $300 for a cast aluminium one. Else you could either fabricate one up out of aluminium/steel or else modify a twin carb manifold off another motor to suit which is what I've done previously adapting 3sge manifolds to suit a BMW & numerous other engines.
But unless you really want/have to run a 4AF you'd probably be better off spending the money your going to spend on manifold,carbs,linkages etc & look at fitting a 4age or something if possible.
If however your keen on going 4AF with twin side draughts let me know & I'll either get a price or else if they aren't all that expensive I'll get one.
atmosports
Postby tenyearguarantee » Thu Oct 06, 2005 2:25 pm
if you could find out a price for the manifold and carbs and stuff it would be much appreciated. I just reckon a twin carb 4af is different is all, no other reason.
tenyearguarantee
Postby atmosports » Thu Oct 06, 2005 4:29 pm
The Manifold is $350 incl GST New
Carbs vary in price but bear in mind you can't get new Weber/Dellorto side draughts they are all s/hand. If you are after new carbs then OER are the way to go, they are a Japanese copy of a Weber with a few modifications, a pair of these in 45mm is $1500 + Gst.
atmosports
Postby tenyearguarantee » Fri Oct 07, 2005 2:56 pm
cheers man, looks like i need more coin than i got
tenyearguarantee
Postby gasman » Fri Oct 07, 2005 9:45 pm
kaching (sound of a cash regester) :D
"What can possibly go wrong?"
gasman
Postby tenyearguarantee » Sun Oct 09, 2005 8:11 pm
is that u offering to finance it?
tenyearguarantee
