t50 in a 4k
t50 in a 4k
Postby keseventy » Tue Oct 04, 2005 10:04 pm
heres the thing i got a t50 from an unknown car and i want to put it in my 4k, the imput spline of the t50 is 21 and output 20. if i used t40 bellhousing from a 5k corona, would this work?
thanks
1977 ke30
keseventy
Postby l1ttle_d3vil » Tue Oct 04, 2005 10:11 pm
im guessing the 4k/5k bolt-patterns are the same so that should be sweet, and as far as I know the only difference between a t40 and t50 is the number of gears so that should be sweet too.
someone else will be able to confirm though :lol:
Postby keseventy » Tue Oct 04, 2005 11:05 pm
can someone confirm :D not that im doubting you but im real eager to do this and to do it right plus my gbox is f**ked lol
1977 ke30
keseventy
Postby AE101_REAR_DRIVE » Wed Oct 05, 2005 2:53 pm
Yeah he is right. But If theres a T40 attached to a 5K when you take the T40 out to get the bell housing count the splines on it if there the same then bolt up if not K50 time maybe??
Why not go for the whole engine no wof agent will pick a 5k from a 4k and you will have more power + a T40 at the least, everything except diff will be bullet proof and it's not like you cant find another K series diff there a dime a dozen.
Thank God Im Not Silent_Knight Other Wise I Would Have To Kill Myself
AE101_REAR_DRIVE
Postby AE85coupe » Wed Oct 05, 2005 3:52 pm
how bout we answer the question, YES it will work man, no problem at all
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby AE101_REAR_DRIVE » Wed Oct 05, 2005 4:12 pm
found a drive shaft yet 85??
AE101_REAR_DRIVE
Postby AE85coupe » Wed Oct 05, 2005 4:14 pm
no sir i can't say i have
Details of car here
AE85coupe
Postby spencer » Wed Oct 05, 2005 4:18 pm
Are big bearing and small bearing t50's bellhousings interchangable?
spencer
Postby AE85coupe » Wed Oct 05, 2005 4:26 pm
they are, but the input shaft bearing bit where is bolts to the bellhousing are different, so you need to just slot the holes to suit
5k t40s are usually 20 spline, so if the dude has a 20 spline t50 it will bolt straight on
Details of car here
AE85coupe
Postby spencer » Wed Oct 05, 2005 4:41 pm
yep sweet just wondering I have a t-50 from a 5k van that is 22 spline. Wouldnt mind putting the older 20 spline t50 behind it so I can use the starly driveshaft and save the 22 spline for a spare.
spencer
Postby keseventy » Wed Oct 05, 2005 9:43 pm
aight. thanks 4 the help
1977 ke30
keseventy
