Re: 20V problems
Re: 20V problems
Postby AE101_REAR_DRIVE » Wed Oct 05, 2005 3:19 pm
Hey guys heres my problem I have a 20V 4AGE and not knowing much about them how do you adjust the idle if you can at all?
Also after a frontal accident I have had to remove the a/c problem is that I now have to much flow over the radiator and the damn p.o.s never gets up to temp anymore.
Any thawts on the radiator aside from putting the a/c core back in or changing the termostat. Been there with the thermostat it didn't work the car just has to much air moving over the radiator.
Was thinking about blocking half of the radiator off is this wise??
Any help would be appreciated.
Thank God Im Not Silent_Knight Other Wise I Would Have To Kill Myself
AE101_REAR_DRIVE
Postby CozmoNz » Wed Oct 05, 2005 3:24 pm
get a geniune toyota thermostat for a 20v from revvy.
you cant have to much cooling bro, your thermostat controls how much flow there is, so it should only be opening when the engine is at its operating temp.
id say you have to low a temp thermo in there.
Idle im not completely sure about on 20v's so i wont comment.
and no, blocking half the radiator is NOT a smart idea.
Rayne For President!
CozmoNz
Postby Fraud » Wed Oct 05, 2005 3:50 pm
IMO the problem does not lie in too much air flow over the radiator at all. As Cosmo said, the more air flow the better. You may find the thermostat isn't right or the water pump is crap :?:
Fraud
Postby AE101_REAR_DRIVE » Wed Oct 05, 2005 4:18 pm
ummm water pump fine it dosn't get up to opperating temp so changing the thermo is the first on my list just one more question for you cozmo if the thermo is jammed open would it ever get up to temp or would it be like driving round with out a thermostat im assuming it would be??
Thanks for your help. :D
AE101_REAR_DRIVE
Postby pervert » Wed Oct 05, 2005 4:22 pm
Any car I've ever had with a $&#$% thermostat struggled to get past the C mark, so ran like shit... 8)
pervert
Postby AE101_REAR_DRIVE » Wed Oct 05, 2005 4:23 pm
thanks so i guess it's new thermo time
cheers for all those who helped
AE101_REAR_DRIVE
Postby MrOizo » Wed Oct 05, 2005 5:22 pm
its all good saying that there is too much air flow but...
when you start the car first thing after a day of sitting there does the fan(s) go full time?
With aircon there is a solenoid in the AC line that i think is pressure activated and makes the fan run full time when removed.
Might wanna look into that as a possibility.
and wont hurt replacing the thermostat :)
MrOizo
Toyspeed Legend
Postby AE101_REAR_DRIVE » Thu Oct 06, 2005 8:43 am
fans dont go full time and the don't even switch on plus temp guages raises when sitting and goes down while moving. Has to be thermo.
AE101_REAR_DRIVE
