Power Problem At Low Revs
Postby Blackrazor » Wed Oct 05, 2005 9:53 pm
Hey guys. Just wanting a bit of diagnostic help with what could be wrong with my 91 N/A SW20 (3SGE).
First, a bit of background. I've just been on annual leave, we went for a drive up north for a week and a bit and visited some places. Anyway, we drove all fine and dandy until we were around Marton. We pulled into Marton to find a public loo, and when i pulled out onto the main highway and put my foot down the engine had no pull. None. It was increasing in revs at a rate of like 100rpm per second. I tried driving like that for a bit and pulled over to check if i'd blown something. Engine smelt fine, no smoke, it all seemed tickety boo. So i took off again, same issue. Anyway, we had to keep on going, so i nursed my car (now capable of doing 0-100 in literally 40 seconds) to Taihape (including one section where i had to drop from 5th to 2nd just to get up a pretty easy hill... i got overtaken by an old lady in a Fiat)...
Once we got to Taihape, i called by a mechanic who suggested i take it by an auto sparky. The sparky checked the spark plugs and noted immediately that they were pretty rooted. While he was there, he checked the leads with a multimeter and said they pretty much checked out, and that they had a problem in SW20's with the leads splitting, but they seemed ok. He also did a compression test, which came out fine. So replacing the sparkplugs (with normal ones not platinums, coz thats all he had), we fired the car back up, and drove off, all seemingly fine.
Anyway, a couple of scares along the way doing what i'll describe later, but we got to Hamilton without major incident. It had been pelting down with rain the whole way so i thought i better check the airfilter wasnt clogged since i hadnt changed it since we had it. Didnt know how to open the airfilter container :oops: so took it to a mechanic who whacked the air filter in, and in the process noticed i was still running the original factory fuel filter. Removed that, watched thick black sludge the consistancy of Caramello chocolate exit the old one, replaced it. Drove all the way the rest of the trip without major issue.
The only remaining problem, and its one i can sometimes duplicate and sometimes not, is as follows : When you try and accelerate off a gear higher than usual, the engine has the same problem with no power, until it hits about 2.5krpm, then all of a sudden all the power is back on tap and away you go. For instance, if i drive up to a small roundabout behind someone travelling slowly, drop down into second and coast around the roundabout in second. Exiting the roundabout i'm doing say 5kph and am on about 1200rpm, if i put my foot down, it just feels like the engine is a 750cc gutless wonder for about 1-2 seconds until the revs hit about 2-2.15krpm and then all of a sudden its all go again. And it only happens in circumstances like that when you try and pull away under load in a gear one higher than perhaps you should be. Its not very common, its only done it 4-5 times since the trip north, and never before that.
Any ideas what could be wrong? My father in law suggests the spark plug leads are faulty, so i've priced up some and its a reasonably cheap option. But any other thoughts?
Off topic slightly : the only other thing weird with it is that sometimes when you walk past the car when its off you can hear a momentary 'electrical sparking' (it sounds like) noise coming from the back left corner of the engine (between the distributor and radiator cap)... its only momentary. Me and a mate noticed it in Wellington, but it only lasts for a half second and occurs randomly at perhaps 5-10 minute intervals. Any idea? We couldnt see any sparks, but it sounds like a sparking of some sort.
Cheers!
Boring Sig
Blackrazor
Postby Alex B » Wed Oct 05, 2005 10:25 pm
Last thing; my car makes that noise too, almost sounded like a solonoid sorta around the charkol box. I have no idea if its related :oops:
Postby vvega » Wed Oct 05, 2005 10:27 pm
the problen you have is ignition componatnts are very problematic and you can often replace a bit or gear and attually not fix the problem
it dose sound like your car was mising the normal regem of maniantance so my process would be :
cap ..leads...rotor
lest that wahy thats that part sorted and we can move onto more serious things
v
vvega
Postby Blackrazor » Thu Oct 06, 2005 12:12 am
vvega wrote:cap ..leads...rotor
cap = ?
leads = spark plug leads?
rotor = distributor rotor?
Boring Sig
Blackrazor
Postby SIKTOY » Thu Oct 06, 2005 8:48 am
cap = distributer cap,
leads = Yes, spark plug leads (& coil lead if you want)
rotor = 20b, just kidding, yes distributor rotor.
ALL MEN DIE, NOT ALL MEN TRULY LIVE!
Current: 80 SR Project,
Check Out My Profile, Including CURRENT Pics!
Previous: 90 GT Sedan, 85 FXGT, 77 SR with 18RG, + many more.
Pink shaved pussy pic!!!
SIKTOY
Postby Mr Revhead » Thu Oct 06, 2005 10:51 am
that "sparking noise" is totally normal. i forget exactly what it is, but i think its to do with the emissons. releasing fuel vapours back into the system or something
Postby XS1V » Thu Oct 06, 2005 10:56 am
That noise you here is the fuel pump doing a return cycle or something to that affect, it seems to happen on all efi cars
ST205 Group A Rallye #2363
XS1V
Postby Alex B » Thu Oct 06, 2005 8:58 pm
Errr are you sure, because my car does it and their aint a injector in site, one hell of alot of emmission control bs on it tho (ie it has an ECU that simply controls emmission control and idle as far as i can tell 8O ) And charkol box is part of the emmission control system is it not?? SO revheads idea makes more sence :arrow:
Postby XS1V » Fri Oct 07, 2005 1:20 am
Yea sort of what i was getting at in a round abouts way :lol:
XS1V
