Coriz wrote:there are no other lights out on dash cluster
i would have thought they would have thrown a code if the airbags had gone off
If the airbag system is the same as other sub systems (eg ABS) the airbag light itself is what shows the trouble codes, if it's been removed or is blown you won't see anything at all.
are you sure it is simple to check if the bulb is blown? it doesn't look easy lol
It is easy but takes a while, all you need is a screwdriver. From memory you need to:
wait until cozmo is asleep
remove the lower dash panel under the steering wheel (4 screws, one in each corner)
lower the steering wheel to it's lowest position
remove the center console trim [remove the gearlever gater and surround (clipped in) ashtray (clipped in), behind the ashtray there are 2 screws, remove these and then the console surround will come out with a small amount of force, unplug the hazard switch and cig lighter]
remove the dash panel that runs behind the steering wheel (there should be one screw at the end that fits under the center console panel, I think the rest are clips but double check)
remove the trim panel above the instrument cluster (clipped in)
you should now have access to 4 screws holding the instrument cluster in, remove these, pull the cluster out as far as possible then reach behind and release the 3 loom plugs and that's it.
You should now be able to manoeuver the cluster out around the steering wheel.
Reverse this to put it back in.
is there any other way to check if the airbags are operational or if they had been fixed or not??
Getting the light working is the easiest thing to try first, after that you really need specialist advice, or a visit from dragonx
