What air flow meter should i use for 4agte
Postby ZETstarly » Thu Oct 06, 2005 11:35 pm
Would like to know wat car i can get an afm off{year+model} that would best suit my 4agze turbo starlet. :)
ZETstarly
Postby Alex B » Thu Oct 06, 2005 11:37 pm
Aw11 and Ae92(early) so cozmo tells me :D
Postby CozmoNz » Fri Oct 07, 2005 12:05 am
or, like, yaknow, a 4agze afm..... >.> as pyro was getting that :P
Rayne For President!
CozmoNz
Postby Malcolm » Fri Oct 07, 2005 12:17 am
I have a feeling that many Toyota AFM's from the same era will work...
Postby spencer » Fri Oct 07, 2005 12:17 pm
yea vauge question what comp you using?
spencer
info
Postby ZETstarly » Sun Oct 09, 2005 2:38 pm
as if i didnt already know wat u have just writen i have built this car from skratch and many others.was only asking because i guy told me to use one out of a camry thought some one could help me with the model.[will be running microtech out of my evo 5 if i sell it]
ZETstarly
Postby ZETstarly » Sun Oct 09, 2005 2:40 pm
that was top the 70 dude
ZETstarly
Postby Bazda » Sun Oct 09, 2005 3:12 pm
Yea u can get one out of a camry like a 1990 model. It will run with the standard 4agze afm ecu as the injectors are the same size and same impedence. Its also bigger than a standard 4agze one. And cos ur turbo blow through it!
