Alternater Noises
Alternater Noises
Postby dotdog » Sun Oct 16, 2005 11:41 am
Hey all, My alt/water pump belt was squeiling yesterday, so it gave it a bit of a tighten up (not excessively tight) and now it seems to be making a werid noise, and that nosie is coming thro my stero speakers as well, any ideas?
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby Crucible » Sun Oct 16, 2005 7:30 pm
Id say the noise through your speakers it electrical interferance, maybe Alternator? It shouldnt be related to you tightening the belt at all and was probley there before maybe?.
I take it the belt isnt perished, or oil soaked? Run a drylube stick or silicone on the belt....it may be glazed, if you aint got either then a crayon will work fine. If the noise doesnt change note - Tensioner, Waterpump or maybe Alternator bearings may need doing.
A dry or slipping belt will give more of a squeel wereas a worn bearing will be more of a rumble .
Tightening a belt will put more load on bearings and if they arnt the best to start with then the noise will become worse.
Hope this helps, Just my 2 cents
TNT
Crucible
Real Life Mechanic
