recondition or replace
Postby nmemr2 » Tue Oct 18, 2005 10:05 pm
hey. i am starting to have issues with my gearbox. crunching into and out of gears and grinding even when clutch is hard to the floor,
i have heard that its massive money if i can find a new one so really my options are to either recondition to a high standard or replace with one from another "organ donor" car
im wanting to know who else has had this problem, more specifically with sw20's and what was done to rectify the problem and how effestive it was compared with the cost
SW20, a work in progress for 2 years now, all i need to do now is work on it
nmemr2
Postby AJz » Tue Oct 18, 2005 10:25 pm
best long term and cheaper option is to replace the box completely. Recondition is very pricey especially if all gears as you say are quite rooted.
pick up a second hand box from a wreckers, tardme. (helps if car is still drivable, lol. But yea, if its not, just try and make sure u dont get ripped off.
Then if your confident, do the work yourself, if not, get a couple of quotes for gearbox swap, or if you have mates who know how to, alot of beer would be needed. 8)
I had vtax :(
AJz
Postby Ae92typeX » Tue Oct 18, 2005 10:58 pm
In most cases i'd say just drop another one in also. Problem with this is you dont really know how long it will last...but its still a hell of a lot cheaper then reco'n a box even if you go through a coupple (depending how you drive predomantly)
In saying that, if you are sure you are going to keep the car for a long time and can do the majority of the reco yourself then it could be an option...
Ae92typeX
Postby fangsport » Tue Oct 18, 2005 11:30 pm
Ae92typeX wrote:In most cases i'd say just drop another one in also. Problem with this is you dont really know how long it will last...but its still a hell of a lot cheaper then reco'n a box even if you go through a coupple (depending how you drive predomantly)
chances are, if you are breaking a few, you're pushing half rooted second hand boxes to their death. ultimately get a couple of cheap second hand ones, bolt on in, and make one goodin, out the 2 others.
i'd far rather know what i'm using is in reasonable condition than a lucky dip, same with engines.
fangsport
Postby nmemr2 » Wed Oct 19, 2005 11:29 am
yea i am going to be keeping the car for a couple years at least, i like the thought of saving money with a used one from a donor but hate the idea of a pot luck item. will have to get a couple quotes and go from there
nmemr2
Postby fuel » Wed Oct 19, 2005 12:09 pm
Are you sure it's the gearbox? It sounds like a hydraulic clutch problem to me...
LOUD NOISES!!!
fuel
Postby RomanV » Wed Oct 19, 2005 1:25 pm
Gearboxes arent that expensive!
Especially for an NA. Couple hundred bucks at most.
Its the labour thats going to kill you though, if you cant do it yourself. :?
Postby nmemr2 » Wed Oct 19, 2005 5:53 pm
yes i am sure its the gearbox. i had the clutch replaced a while ago and i took my car to the mechanic today and he confirmed it was the gearbox, mainly the front gearbox bearing is munted causing the other damage.
i have someone who can help me change the gearbox for a case of beer but want to know if its worth it to replace with a cheapie
nmemr2
Postby fangsport » Wed Oct 19, 2005 6:08 pm
if the bearings have let go, chances are that metal could have gone thought the gears and stripped the hardening off them. quite common in the mid-80's FWD nissans.
fangsport
Postby peas » Thu Oct 20, 2005 4:14 pm
fuel wrote:Are you sure it's the gearbox? It sounds like a hydraulic clutch problem to me...
That's what I initially thought reading the post... Hope your mechanics right... I had a problem similar to this in my GT4 and all that it needed was the clutch pedal bracket to be welded up as it was flexing. My Levin had similar worries until I replaced the slave cylinder.
But if your sure its the box... I would get it rebuilt but thats just me... I like to know that stuff has been done properly while I'm driving. Just a peace of mind thing.
'97 Caldina GT (ST215G)
peas
Postby nmemr2 » Thu Oct 20, 2005 8:28 pm
my mechanic is a really good bloke, if he tells me its one thing and i get him to fix. if it doesnt solve the problem he will re-diagnose the problem and fix it at no cost to me.
and so far he hasnt been wrong about my car. and he was the mechanic that did all the work on the clutch about 6 months ago and have had no problems with that
nmemr2
