starters
starters
Postby trdfxgt » Thu Oct 20, 2005 1:54 pm
hey guys is there different size starter motors for fwd 4ages ?? in looking to get some more clearance when i bolt on my turbo
trdfxgt
Re: starters
Postby Distrb » Thu Oct 20, 2005 2:50 pm
trdfxgt wrote:hey guys is there different size starter motors for fwd 4ages ?? in looking to get some more clearance when i bolt on my turbo
All the ones i've come across have been virtually the same size
Easiest thing to do IMO is, get a gearbox that has a bulge for the starter motor on the intake side of the block and fit a 20v starter.
Distrb
Regular Poster
Postby Jebus » Thu Oct 20, 2005 3:16 pm
There are differences in some, in relation to where the solenoid sits, some sit closer to the block than others so will help clear your exhaust better than ones that stick out further., however theyre the same physical size.
Jebus
Postby gepsk8 » Sun Oct 23, 2005 11:36 am
smallport 4age's are smaller, well it was on my 1.
get it overhaul if you got the coin b4 you finish to turbo convertion as its an ass to get out once you put the turbo in.
gepsk8
