Dragger_Dan wrote:fangsport wrote:does it have a full compliment of coolant??
This is the most likely explanation. Try burping the cooling system.
Skidman wrote:Im not getting smart, only curoius, how would lack of coolent effect the engine in this way? Why would the ecu's failsafe do this for high temp? wouldnt the temp gague in the dash be reading way high beacause of the steam?
Skidman wrote:Yep but thats when all the water is lost not just an air pocket...
All of the cars that have had an air pocket that i have had to purge out have shown it by the temp gague sailling right up to the big 'H' and i have never seen a car that has the described problem that has been fixed by simply purging the system.
Plus if the system was doing that, reading cold, then hot, seem as the ecu temp sensor is right next to the temp gague sensor wouldnt you see the temp gague going in-sync with the high/low idle???
fangsport wrote:the sensors give the ecu certain values at consistant levels/ temperatures, if the coolant level is a bit low, the signal will be intermittant , as it won't be consistantly immersed, it will only be getting washed by the passing coolant.
steam, not being a liquid, usually won't give a reading on a temperature gauge, unless it has super-heated the passing water(if the water level is high enough ) i.e blown H/Gasket.
