KE70 Light/Indicator Problems
Postby pervert » Mon Oct 24, 2005 2:34 pm
KE70 Corolla, have checked all bulbs, earth's/wires/fuses...can't find any faults.
Problem is, neither park lights go, and drivers side front and side indicators only illuminate ever so slightly when they flash...
Someone has tampered with the wires on the drivers side, so I've stripped everything back and re-wired it all, going to the front indicator is a green/orange, white/black and green/yellow wire.
If you connect the W/B and G/Y wire to the front indicator (like it is supposed to be?), then nothing flashes, but if you connect the G/O and G/Y wires, then it illuminates ever so slightly, along with the side indicator.
If you connect no wires, the drivers side park light flashes slightly like an indicator...
Hope this makes sense...any ideas?
Thanks.
pervert
Postby fangsport » Mon Oct 24, 2005 6:44 pm
dodgy earth. check that there is sufficent earth to the dash, as that is where most of the #E70 lights are earthed through.
fangsport
Postby pervert » Mon Oct 24, 2005 8:13 pm
Thanks, I'll give that a go tommorrow... 8)
pervert
