GT4 Celica ST185 Rear Wheel Drive Conversion !?
Postby toyoda » Sun Oct 30, 2005 9:31 pm
hi all , i have a st185 celica gt4 ,would like convert it to rear wheel drive , dont know if its possible ,heard people said just remove front drive shafts ? any advises , thanks heaps' :)
toyoda
Postby Andy7447 » Sun Oct 30, 2005 9:33 pm
yea im wanting to know more myself, wouldnt mind doing it sometime
1989 Celica GT-FOUR
Andy7447
Postby gdsup » Sun Oct 30, 2005 9:34 pm
usually need to lock centre diff and remove front drive shafts
gdsup
Postby Malcolm » Sun Oct 30, 2005 10:24 pm
if you remove the front driveshafts the car will drive like it has a slipping clutch, due to the viscous center LSD. You would need to get an early 165 box with the locking center diff. Still, it's a bloody stupid idea, if that's your cup of tea maybe you'd be happier with a gts-t?
if you really want a RWD, do the conversion properly, although IMO converting a normally transverse engined car to longitudinal, without providing serious structural reinforcement, is also bloody stupid, as the chassis is designed for loading due to the engine torque on one axis, and you're making the torque act about an axis 90 degrees offset from the intended one, which would surely lead to severe twisting of the chassis if you have any decent amount of power
Postby Malcolm » Sun Oct 30, 2005 10:26 pm
also removing the front driveshafts will cause the front wheel bearings to fall apart and the wheel to fall off. You need to leave the outer cv's in
Postby sergei » Sun Oct 30, 2005 11:16 pm
or just use massive bolts instead...
Postby peas » Mon Oct 31, 2005 7:12 am
And I wouldn't think that the boys at Toyota had RWD conversions in mind when they were engineering your driveshafts or diff... I doubt they would last too long if any decent amount of power or some "spirited" driving was encountered. You are asking something to handle all the load as opposed to approx 50% of it... just doesn't add up.
And as said... why? :roll:
'97 Caldina GT (ST215G)
peas
Postby sergei » Mon Oct 31, 2005 8:15 am
pple these days like oversteer
Postby Malcolm » Mon Oct 31, 2005 10:48 am
if you want a rwd car then buy one
you can also put the st185 center diff into a RWD mode, but I'm not telling you how because there's about a 90% chance it will break if you drive it with any vigour
Postby Rob » Mon Oct 31, 2005 6:06 pm
Theres a guy in auzzie with a 1uz converted to rear drive but hes an engineer and made most of the components himself I do believe as you need to move the steering rack and make the tunnel bigger to accomadate a rear drive gearbox. I have been considering a change my self but it would take a fair wack of time.
That guy in Auz reckons his handles heaps better now too
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby Malcolm » Mon Oct 31, 2005 6:58 pm
isn't that one also known for randomly popping the boot open due to chassis twisting? I mean no disrespect to Justen's work, he's done an excellent job and made a crazy beast, but I sometimes wonder about the structural integrity of an uncaged FWD based car with a high power RWD conversion
Postby RunningRich » Tue Nov 01, 2005 8:11 am
Rob wrote:Theres a guy in auzzie with a 1uz converted to rear drive but hes an engineer
Actually, he works for the EPA in Canberra! Has some cute friends too, very friendly ;-)
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Akane » Tue Nov 01, 2005 11:29 am
It's the whole skids thing catching on now......... weather I was in it since 2000 :/
Postby CozmoNz » Tue Nov 01, 2005 12:05 pm
All_Fours wrote:isn't that one also known for randomly popping the boot open due to chassis twisting? I mean no disrespect to Justen's work, he's done an excellent job and made a crazy beast, but I sometimes wonder about the structural integrity of an uncaged FWD based car with a high power RWD conversion
haha, is that the reason for it? i was wondering why that happened :D
needs a rollcage i say
Rayne For President!
CozmoNz
Postby bad20v » Tue Nov 01, 2005 12:17 pm
I think he want to do this coz he used to have a pretty phat AE86, and he might be missing that tail happy action in the sun. :P
Thank-You.
bad20v
Postby deaf_rattle » Tue Nov 01, 2005 5:47 pm
try jacking up the st185 from the sill on one side.
the door wont close nicely now will it?
chassis flex from nam.
it would be cool to make a decent rwd st185, but the money you would need to do that right, would be enough to buy a decent rwd and then some
Postby Malcolm » Tue Nov 01, 2005 6:23 pm
to be fair, my doors open and close fine with one corner jacked up. However the torque of a decent engine in RWD layout puts a sh*t load more stress into the chassis than jacking one side up
Postby Rob » Wed Nov 02, 2005 6:23 pm
I was watching a show on sky about building mustangs into shelby 500's and they put a big cross brace under the car to restrict the twisting. Didn't look too heavy either.
Rob
Postby toyoda » Mon Nov 07, 2005 10:04 pm
thanks alot guys !
toyoda
