1990 FXGT AIR BOX QUESTION
Postby B1NZ » Tue Nov 01, 2005 5:37 pm
Ok, so after the ex owner of my FXGT putting a pod filter on it, there seems to be a couple of dangly bits in the engine bay where the airbox is supposed to be,
Theres what i think is the air temp sensor which looks like a plastic needle type thing, but then theres a big rectangular box thing that looks like its supposed to be intthere somewhere? Does anyone know what it is?
BTW : smallport redtop 16v non-tvis if that helps!
Can anyone send me a pic of thier engine bay with a factory airbox if possible: B1nz2000@yahoo.com
And if anyone has the airbox etc for sale let me know
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby B1NZ » Tue Nov 01, 2005 5:39 pm
Looks like this i think if the FXGT's are the same as the Levin/Trueno AE92
And the rectangular bit is the number 2 in the photo
Subaru GF8 Wagon
B1NZ
Postby Rick » Tue Nov 01, 2005 5:41 pm
I have a factory airbox if you are interested
Have a look here for a photo:
http://forums.toyspeed.org.nz/viewtopic.php?t=38833
Postby FLAWLES » Tue Nov 01, 2005 10:27 pm
number one is the resanotor box these little thing are pretty trick
number two i have no idea
FLAWLES
Postby Caveman » Tue Nov 01, 2005 10:50 pm
I was looking at number 2 a few days ago.
It is seperate from the airbox but has a pin sized hole going into it after the filter. It then has a vacum line which goes to the T/B, not sure if its before or after the butterfly, I think its behind.
At first I thought it was to control the idle but I have no idea.
Caveman
Postby B1NZ » Wed Nov 02, 2005 5:11 pm
i already guessed no 1 was a resonator, number 2 is the problem? Debateing wether i need to plumb it back in, get a custom intake pipe made up or get the factory air box
Subaru GF8 Wagon
B1NZ
Postby matt dunn » Wed Nov 02, 2005 11:11 pm
I figured this out ages ago when I had my FX, but so long ago that I have forgotten exactly what it was?
I think from memory indide that box there is a VSV that is used for a/c idle up or similar?
I just threw the spare airbox I had like that out last week too.
Matt
Postby Caveman » Thu Nov 03, 2005 12:05 am
matt dunn wrote:I figured this out ages ago when I had my FX, but so long ago that I have forgotten exactly what it was?
Matt
That would make sense as theres a small hole leading into it and a line going behind the TB. Some sort of idle control. Thanks now I know I can remove it 8)
Caveman
Postby gordon77 » Thu Nov 03, 2005 8:24 am
matt dunn wrote:I think from memory indide that box there is a VSV that is used for a/c idle up or similar?
its definatly an idle up - dunno about a/c, i thought that was done on vaccum .If you pull the hose out that goes to the throttle body the idle speed goes through the roof, block the hose and the idle speed drops (stalls the car sometimes too 8) )
What is RR?
gordon77
Postby B1NZ » Thu Nov 03, 2005 5:14 pm
so do you think i could make a custom intake up and plumb number 2 in approx where number 1 on the picture is?
Subaru GF8 Wagon
B1NZ
Postby gordon77 » Thu Nov 03, 2005 8:09 pm
i am currently modifying the vsv (number 2) to go in the cold air box i made. its a bit of a mish to make it look good and work at the same time :wink:
in answer to your question i think its probably better if you leave it there as its part of the factory cold air box.
What is RR?
gordon77
Postby B1NZ » Fri Nov 04, 2005 5:14 pm
thats what i thought, i have to get the airbox as the previous owner binned it and left the air temp sensor and the other dangly bit floating in the engine bay.
Could these sitting on a warm gearbox next to the engine be a reason for exsessive fuel consumption?
Subaru GF8 Wagon
B1NZ
Postby Caveman » Sat Nov 05, 2005 1:06 am
I would have thought if the ECU were reading higher intake temperatures it would dump less fuel.
Caveman
Postby gordon77 » Sun Nov 06, 2005 9:41 pm
my air temp sensor was out of the air box untill i found it hanging while doing other stuff. put it back in and it made no difference. keep in mind i dont have a dyno handy...
What is RR?
gordon77
Postby Kermit12a » Mon Nov 07, 2005 8:16 am
I have just sorted this prob on my AE82. But I never saw a needle.
Just two bits of piping. One going to a solinoid and the other to some fuel/idel thing.
Looking at my mates car. They needed to go into a T joint with the smaller one going in the side of the T befor the idel sensor.
Have put a hole in the duckting that leads from the Pod to the intake. Works great and now my revs do not bounce when ideling. This was annoying as it would go so low at times it would stall.
AE82 FXGT all the way
Go the Old School
Kermit12a
Postby Zyros » Mon Nov 07, 2005 4:36 pm
I have the same car..
I just ripped the old air inbox out and put a podfilter in, the sensors is just dangling around.. seem's to run fine..
Should i somehow put them back in tho?
I have that neddle thing, and the tempature sensor.
Zyros
Postby gordon77 » Mon Nov 07, 2005 4:38 pm
Kermit12a wrote:I have just sorted this prob on my AE82. But I never saw a needle.
can you post pics?, not queit grasping what you have done...
What is RR?
gordon77
Postby Kermit12a » Mon Nov 07, 2005 4:50 pm
Sorry I do not have access at work and do not have a digi cam. Will try and get one off a mate and see if I can load some pics for you.
This is for an 1985 so it works in air sensors. if you have one that is map it might be a little different. But should be similar.
Will see what I can do
Go the Old School
Kermit12a
Postby gordon77 » Mon Nov 07, 2005 5:02 pm
yeah my car is map so it will be different.
What is RR?
gordon77
Postby Kermit12a » Mon Nov 07, 2005 5:07 pm
Then sorry it will be very different but if you go to Pic a Part you should be able to rip out an air box or dirt
Go the Old School
Kermit12a
