Injectors
Injectors
Postby Damio » Sat Nov 05, 2005 3:53 pm
Does any1 know if 3sgte injectors will fit in a 4age 20v
Damio
Postby luvnit » Sat Nov 05, 2005 4:04 pm
unless your pushing some decent power you shouldnt need them, though if you do want to upgrade then afaik injectors out of a 4agze should go straight in and do the job
i want a turbo, why not 2... new car
1993 mitsubishi galant vr4 TT
now with a poked rear diff
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1464 - updated with new car
luvnit
Postby Damio » Sat Nov 05, 2005 4:12 pm
im gona need sumfin pretty heavy duty wif the size of turbo i got, dont think ze injectors will cut it, found a set of 3sgte ones but wana know if theyl fit b4 i get them
Damio
Postby Mr Revhead » Sat Nov 05, 2005 4:19 pm
20vs like the 3sgte are side feed, 4agzes are top feed so will not fit.
3sgtes ones should do the job, but i think there are a coupla different sizes
Postby fivebob » Sat Nov 05, 2005 4:26 pm
Gen I, as fitted to the ST165 are top feed and will not fit.
Gen II, (early SW20 & ST185) are 430cc Side feed injectors and will fit.
Gen III (ST205 & SW20 after Oct '93) are 540cc side feeds and will fit.
Gen IV (ST215) are top feed and will not fit.
Postby Damio » Sat Nov 05, 2005 4:27 pm
sweet, cheers 4 that, the person i was going to buy them off was miss leading me, thought id better check
Damio
Postby Mr Revhead » Sat Nov 05, 2005 4:29 pm
fivebob, have you got the injector colours handy?
Postby Damio » Sat Nov 05, 2005 4:38 pm
the 1's for sale are the "Gen II, (early SW20 & ST185) 430cc Side feed injectors" which according to fivebob should fit then, hmm mite b a goer, wat u think Mr Revhead?
Damio
Postby Mr Revhead » Sat Nov 05, 2005 4:40 pm
i bloody hope they fit, thats what im gunna use!!
Postby Damio » Sat Nov 05, 2005 4:43 pm
haha tru, well if ur doin it il follow like a sheep to the slaughter, cheers guys!!!
Damio
Postby fivebob » Sat Nov 05, 2005 4:44 pm
The colours are as per the Apexi table, I can't be 100% sure they are correct though.
Black- 430cc from the 3S-GTE (SW20)
Red - 540cc (listed as 530cc) from the 3S-GTE (SW20)
I have no listings for the ST185/205 but I assume they were the same.
Others that may fit are;
Yellow - 380cc from a IJZ-GTE (JZX90)
Grey - 430cc from JDM 2JZ-GTE (JZA80)
Purple - 520cc from Export 2JZ-GTE (JZA80)
Postby Akane » Sat Nov 05, 2005 11:57 pm
Users browsing this forum: Bing [Bot] and 19 guests
