no_8wire wrote:Idea no.2
Tubular manifold....
Most people when they start to modify the car is extrators...
Why doesnt anyone think about flow on the intake side?
RomanV wrote:I cant see any advantage to a dual throttle setup, how you propose.
RomanV wrote:If you had 2 throttles that were the same diameter as the original, at 40% throttle you'd effectively be at 80% throttle!
Which would make the car rather twitchy I would imagine.
Santa'sBoostinSleigh wrote:RomanV wrote:I cant see any advantage to a dual throttle setup, how you propose.RomanV wrote:If you had 2 throttles that were the same diameter as the original, at 40% throttle you'd effectively be at 80% throttle!
thats just contradicting yourself
Truenotch wrote:But I think this could work, bu would take too much stuffing around as it hasnt been done.
Truenotch wrote::D Aw11 air filters have no airflow anyway... Mines behind the battery.
What are you trying to achieve?
What is the car/engine? By quickly reading the posts it's a bluetop 4AGE with TVIS?
2) Since one induction path is longer than the other that may have some issues.
N/a's didnt have the hole in the boot did they
I reckon a goer of an idea might be the combination of these two ideas...
Oh. Fair enough then. I retract my statement about different lengths...no_8wire wrote:They would be same length...the intake pipes would curve down to meet under the manifold join to 0ne the run to air filter.
no_8wire wrote:N/a's didnt have the hole in the boot did they
Yes all facelift AW11s had the airfilter located in the boot.
