T4-T60-1 turbo info needed!
Postby Damio » Sat Nov 12, 2005 8:05 pm
Does any1 know anything bout the T4-T60-1, need to know hw much boost it good for and how quick it spools.
Damio
Postby nite b » Sun Nov 13, 2005 10:41 pm
Version/trim of T60-1? Plain or Ball Bearing? A/R's? Brand?
Then engine may possibly play a small factor, pretty laggy on a 2K, poss good on a 2JZ though....
:D
Convert Ltd
The conversion specialist
nite b
Postby Phothog » Thu Nov 17, 2005 10:21 pm
As nite b has said.. it all depense on the engine....
a 60-1 will flow more boost than a standard engine will handle..
spooling... well if you have a well sorted 1 - 2jz ( as one of my customers has) it could spool before 3000rpm... but if you had a 4efte with nothing done to it it could spool at 9000rpm....
and it also matters what is on the turbine side... standard TB03, stage ? shaft, O or P trim .48 to a 1.32 A/r turbine housing...
a 60-1 is just a name for the compressor wheel and nothing else...
(the above mention 1.5jz was producing about 430kw @ 6500 Rpm
spooling @ about 3500rpm on 24psi of boost, it use to spool before 3000rpm with a smaller turbine housing.)
Phothog
