l1ttle_d3vil wrote:pretty much everything else has been fixed but now im just having problems with my 4age bluetop idling at cold. once it warms up a little bit it'll idle by itself sweet, until then I have to hold the revs above an idle myself.
what would be causing this? is it likely to be the cold start injector not working? or a vacuum leak? thats about all I can think of off the top of my head.
it also seems to have some lag when I put my foot down [from an idle], its as if its going to stall at first then the revs start to lift like they should.
this also fixes itself once it warms up, or if I unplug the map sensor from the loom or take the vacuum hose off the manifold.
i've checked the map sensor and TPS and they are both fine so it can't be a faulty reading from them. anyone got any other ideas?
l1ttle_d3vil wrote:cheers, im not familiar with the stepper motor or bypass valve you're talking about on any of the 4ages, i've only heard of them but have no idea what they look like![]()
anyone got pics or can elaborate? cheers
l1ttle_d3vil wrote:sweet so I'm guessing 5 is for the water, whats 6 for?
2LTR Rona wrote:#5 & #6 are the intake and return for the coolant from the block, there should be a rail that runs along the drivers side of the block which then ties in with the piping at the back.
*Steph* wrote:My 4AGE does same thing and i got told its my faulty air bypass valve.
