Q's for those with 20v flywheels in thier t50
Postby AE85.6 » Tue Nov 15, 2005 9:49 pm
i know the gtz flywheels are the biggest and dont fit inside a t50 but what about the others,
i thought the 20v flywheels were the biggest that would fit inside a t50 but how do these compare diametre wise to a 16v one ? is there is any size difference or is it just that they are lighter ?
i would assume that if the 20v flywheel is a bigger diametre but still fits in a t50 i could then use an ae111 clutch and cover as apposed to ae86 ones which would give a bit more surface to grab also, as long as all this fits into a t50 sweet
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby Rick » Tue Nov 15, 2005 10:34 pm
Pre 1989.5 clutch dia 200mm
Post 1989.5 clutch dia 212mm fitted to 4/7afe and 20valve
all 4agze clutch dia 224mm
212mm is the largest clutch to fit into a T-50 bell housing.
Postby gdsup » Wed Nov 16, 2005 8:41 am
late model ZE are 236mm i believe
gdsup
Postby AE85.6 » Wed Nov 16, 2005 8:38 pm
obviously the flywheel is still the biggest componant so using the clutch and cover from a 20v wont foul anything ?
AE85.6
Postby Stealer Of Souls » Thu Nov 17, 2005 8:26 am
What will fit into a K50?
'86 AE85.5 Levin
Stealer Of Souls
Postby suberimakuri » Thu Nov 17, 2005 10:44 am
run a nite parts A->W bellhousing and revel in the 236mm clutch!!!
it takes a little mod to fit, else 225mm no prob.
suberimakuri
Postby Stealer Of Souls » Thu Nov 17, 2005 2:44 pm
Karl_Skewes wrote:run a nite parts A->W bellhousing and revel in the 236mm clutch!!!
Is this for the K50 or T50?
'86 AE85.5 Levin
Stealer Of Souls
Postby 2LTR Rona » Thu Nov 17, 2005 2:54 pm
Karl would be referring to the W series boxes i.e. W55, W57 etc
Hence the A - W :wink:
2002 Altezza, 1974 KE25
2LTR Rona
Postby AE85.6 » Thu Nov 17, 2005 7:21 pm
so 212mm 20v flywheel plus ae111 clutch and cover plates to match will fit into my t50 sweet as ???
AE85.6
Postby AE85.6 » Sun Nov 20, 2005 5:06 pm
bump
AE85.6
Postby AE85.6 » Mon Nov 21, 2005 8:32 pm
AE85.6
Postby AE85.6 » Wed Nov 23, 2005 10:17 am
bump
AE85.6
Postby suberimakuri » Wed Nov 23, 2005 10:27 am
20v clutch and flywheel fits inside factory A -> T bellhousing.
Same clutch spline too.
4AGZE clutch has different spline, and that flywheel & clutch combo only fits inside Nite Parts A -> W bellhousing.
suberimakuri
Postby AE85.6 » Sat Nov 26, 2005 4:38 pm
sweet cheers man,
just waiting for clutch to arrive now.
that will do for now thou as im not making big ponies or anything but if a turbo finds its way under the hood sometime in the near future i may need to source one from ya.
AE85.6
Postby AE85.6 » Sat Jan 21, 2006 9:20 am
for anyone that has fit a 20v flywheel into a t50 was there any tricks to actually getting it in ???
i could get the gearbox most of the way on except couldnt push it the last about 10mm on.
i assumed this was because the shaft was not lined up and was not feeding through the flywheel into the pilot bearing but it looks sweet and the clutch plate looks pretty much centred.
AE85.6
Postby sk1dlet » Sat Jan 21, 2006 1:16 pm
no u shouldn't have a problem with it i have a 20v flywheel in my t50 maybe it's not centred up with the spigot bearing
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby AE85.6 » Sat Jan 21, 2006 2:09 pm
ye thats what i thought, slowly nipping the surounding bolts up and it seems to be going on now, will advise as it hopefully goes back on
AE85.6
Postby AE85.6 » Tue Jan 24, 2006 6:40 pm
a little massaging and sweet as baz
AE85.6
Users browsing this forum: No registered users and 34 guests
