4age silver top radeator set up in mr2
Postby blue-smoke » Fri Nov 18, 2005 10:45 am
i have just put a silver top in my mr2 but am haven a problem with the radeator set up , could anyone help me with how you have set up yours
blue-smoke
Postby Malcolm » Fri Nov 18, 2005 10:52 am
what's wrong with the radiator set up? the stock one is plenty for a 20v (it's plenty even for a 3sgte)
Postby blue-smoke » Fri Nov 18, 2005 5:24 pm
well im mainly after a diagram of the cooling system on the mr2s and a diagram of the 20 valves so i know where to make the concetions
blue-smoke
Postby Malcolm » Fri Nov 18, 2005 5:27 pm
well there's only 4 connections that come off the motor
2 big ones (one on each side of the engine) that go to the radiator, and 2 small ones that go to the heater - pretty simple
Postby blue-smoke » Sun Nov 20, 2005 11:19 am
yeah i know that i need to know which one is the outlet and which is the inlet?
blue-smoke
Postby 85AW20v » Sun Nov 20, 2005 1:13 pm
The 2 radiator pipes that come from the front and come out behind the fuel tank are connected as follows: top pipe goes to head outlet beside number four exhaust port. Bottom pipe goes to thermostat housing on the back of the head. It's back to front to the way the 16v is connected.
I don't know about the heater hoses as I've taken those out of the racecar but it shouldn't make much difference which way those are as its only a loop from the back to the front of the car.
I moved the filler neck from the right hand side by the strut to the firewall on the left. From memory I didn't need any additional hoses either - just used the same ones but in a different configuration.
Hope that helps.
See ya
Simon
85 MR2 20v
85AW20v
